Result: Cancel after Firmware Update
3339 12 2015-1-7
richard
Flight distance : 990781 ft
Did a Firmware Upgrade and the following order:
Copied the firmware file to the SD Card
Powered up the Inspire
Powered up the Remote
Powered up the App
Chose the option to upgrade the firmware.
Took 15 mim and it did make it to 100%
Message:  Firmware complete, restarting
Once restarted, I powered down the inspire; took out the SD card and check the .TXT file.  Mine says (results: cancel)
I deleted the .TXT file and tried to update the firmware again.  Tried the sequence listed above but i'm not given the option to update.
2015-1-7
rbendjebar
Flight distance : 3170190 ft
Try to power up RC, then Inspire and check in the app to see what firmware version is installed. If v1.2.0.14, you are good to go.
2015-1-7
travissrt
Flight distance : 68555177 ft
I had same thing, called DJI and they said i'm good to go.  Flew afterwards with no issues.
2015-1-7
skinleverton
Same for me, but app said latest version so up it goes.
2015-1-7
richard
rbendjebar Posted at 2015-1-8 01:48
Try to power up RC, then Inspire and check in the app to see what firmware version is installed. If  ...
Where do you see the firmware version?  when I click on the app, I see a version in the lower right corner at start up that is the App Version.
Thanks,
2015-1-7
MTShipp
I had the result: cancel too but mine flies fine.
2015-1-7
mvdwildenberg
I had the same problem.
On the sd card there is a hidden folder \MISC\LOG\WM610_FW_LOG_AB.TXT
It showed this text:
[00004226]Packet [C:\WM610_FW_V01.02.00.14.bin] detected.
[00004243]Packet upgrade start...
[00004262]Packet checking...
[00004273]Done.
[00004282]Version checking[1]...
[00004292][01 00] v1.3.1993 -> v1.3.1993
[00004331][03 05] v34.1.0.5 -> v34.1.0.5
[00004371][03 06] v1.14.3.7 -> v1.14.3.7
[00004386][04 00] v1.5.0.61 -> v1.5.0.61
[00004411][05 00] v2.0.6.0 -> v2.0.6.0
[00004428][08 00] v1.10.0.14 -> v1.10.0.14
[00004446][09 00] v1.3.6.3 -> v1.3.6.3
[00004472][11 00] v3.0.0.11 -> v3.0.0.11
[00004511][12 00] v1.3.0.60 -> v1.3.0.60
[00004571][12 01] v1.3.0.60 -> v1.3.0.60
[00004631][12 02] v1.3.0.60 -> v1.3.0.60
[00004691][12 03] v1.3.0.60 -> v1.3.0.60
[00004741][15 00] v1.1.1.0 -> v1.1.1.0
[00004771][17 00] v1.0.2.4 -> v1.0.2.4
[00004851][17 01] v1.0.0.9 -> v1.0.0.9
[00004876][19 00] v1.0.8.3 -> v1.0.8.3
[00004884]Packet upgrade cancelled at version checking.
Maybe firmware upgrade gives the message: cancel, because all is up to date.
I contacted DJI about this CANCEL -problem, and they said the upgrade was fine.
I didn't fly jet, because of the bad weather.
2015-1-7
chrisgeigerphot
Flight distance : 13046529 ft
I also got the cancel message but it flies fine after the update.
2015-1-7
DJI-Autumn
China
If you can start the motors and the aircraft flies fine, the update is successful.
2015-1-7
DJI-DingC
China
"Result: cancel " status indicating that firmware on your aircraft is already up-to-date and system has skipped the current update. Power on your aircraft and launch the DJI Pilot App, if there is no message to prompt you to update the firmware, it means your firmware is already up-to-date and no update is required.
2015-1-7
dundee
Flight distance : 33550 ft
Thailand
Latest firmware V01.02.00.16
Anyone can confirm my Inspire has the correct firmware installed ?
See attachment for screen-dump DJI-Pilot
2015-1-27
dundee
Thailand
more safe to first start transmitter and after that the inpire.
2015-1-27
airymok
Flight distance : 2623652 ft
China
"cancel" in the txt file means u r already in latest firmware. And if APP doesn't tell u firmware need update, it also means u r already in latest firmware.
2015-1-27
