DJI-Adela
When Briefcase Mode is switched on, the Ronin will be able to seamlessly transform into this operational mode. With Briefcase Mode turned off, the Ronin will continue to allow the Roll axis to follow.
If your problem is that you can not toggle on/off the Smooth Track in the Assistant App, it may be because the firmware is not compatible, then please upgrade the firmware to the latest first.
Wait for your feedback! |
