Active obstacle avoidance question mark
1088 12 2016-3-1
GoDrone.me
Flight distance : 45928 ft
Malta
So it seems an awesome feature, but by the looks of it, this is front facing and not 360 degrees, what good will this do when orbiting and focusing on the subject in the cente?
2016-3-1
DJI-Ken
Flight distance : 1515312 ft
While orbiting you still need to be aware of your surroundings.
The obstacle avoidance range is 60 degrees to the sides and 30 degrees up/down.
2016-3-1
pidetectives
Flight distance : 2131073 ft
DJI-Ken Posted at 2016-3-2 02:36
The obstacle avoidance range is 60 d ...
So not so good for close quarters flying inspections?
2016-3-1
DJI-Ken
pidetectives@ya Posted at 2016-3-2 02:51
So not so good for close quarters?
It will work better than you think, wait until you get yours (hope you buy it) and you'll see how incredible it is.
2016-3-1
pidetectives
DJI-Ken Posted at 2016-3-2 02:54
It will work better than you think, wait until you get yours (hope you buy it) and you'll see how  ...
I do need it for pipe inspections for water  company. Sadly camera is not interchangeable so it would take a flir thermal camera also.
           Opps wishful thinking
2016-3-1
Michael M
Flight distance : 1984898 ft
what if you have a tree behind you and it avoids the thing in front and bangs into the thing in the back?  I tree
2016-3-1
DJI-Ken
Michael M Posted at 2016-3-2 04:16
what if you have a tree behind you and it avoids the thing in front and bangs into the thing in the  ...
If you go through a tree and the one ahead is huge, it will stop and climb (not go backwards)
2016-3-1
GoDrone.me
Malta
DJI-Ken Posted at 2016-3-1 19:54
Guess seeing is believing ;)
Really don't want to be a negative nancy, complaining about these new features without even having used them, it's just that I would have made this feature 360 degrees or at least one in each leg
2016-3-1
vr-pilot
Flight distance : 4668169 ft
GoDrone.me Posted at 2016-3-2 04:38
Really don't want to be a negative nancy, complaining about these ne ...
It works in the direction it looks. So "normal" and "tap" modes being straight ahead might not be a problem. But what about "active track" mode when the P4 flys sideways or transitions into backward dirctions, e.g. when the target starts moving in the opposite direction...?
2016-3-1
sfcordova
I would have really liked if not 360 obstacle avoidance, at least two more sensors in the forward facing direction of the camera and at least two sensors in the rear of the P4 (from the camera's perspective).  I guess there still needs to be a high level of pilot experience when not flying in the same direction as the camera is facing.  That's okay, but I've been seeing videos where DJI suggests that you don't need to have much experience piloting.  In my case, I'm happy with the new system as having the collision avoidance sensors in the P4 will only help me fly better, but I would still rely on my own sight and experience to make sure I don't crash.  Interestingly enough, I just crashed my P3 Pro last month.  I was flying in cold weather and had the latest firmware upgrade which was supposed to help with the batteries in cold weather flying.  I was at about 30% battery and around 300ft in the air.  I decided to bring it down to not risk any issues as I had noticed a quick descent in battery life on that particular flight.  As it was maybe 20ft in the air, I was very near some elevated train tracks that were supported by cement columns.  I thought it would be a nice shot if I flew in between them.  My first attempt was not straight down the center as there was a bit of wind.  I was going for a second try when my battery was somewhere around 25%, I don't remember exactly, wherever the controller gives you a Low battery warning.  I decided to land it, but since there was snow on the ground, I turned my head for 1 bleeping second to look for a dry spot to land and the RTH took over!!!!!  In a split second and because I was underneath the train tracks, it flew straight up.  I tried taking over but it was too late.  It crashed straight into the tracks and came down about 50 feet.  Frame bent and landing gear broken.  I bought a new shell, and replaced the motors.  One motor wouldn't spin.  After troubleshooting by moving motors around, found the problem to be the ESC. Found a main board with new motors on Ebay for $340.  Around $500 later, drone is up and flying but I occasionally get the jello effect from the gimbal.  Adjusted gimbal after the crash and close to being back to normal.  I blamed myself for the crash, but if it would have had a sensor on top. it would have saved me $500.  Anyhow, my P3P is 90% back to normal, but that 10% I am missing is a perfect excuse to get the new P4.
2016-3-1
mcphipps900
OK.
Who is going to take this bad boy up to it's max speed of 44mph and run it directly at the wall to check the Obstacle Avoidance.
Let me know if it works.
2016-3-1
mrGREEK360
Flight distance : 236414 ft
mcphipps900 Posted at 2016-3-1 19:27
OK.
Who is going to take this bad boy up to it's max speed of 44mph and run it directly at the wall  ...
Most likely will smash into the wall as collision avoidance is recommended in slow mode which is slower then the phantom 3 full speed.
2016-3-1
mcphipps900
Still, would you try it?
2016-3-1
