Geebax
'I did all the right things that all drone pilots should do. Registered my Drone with FAA for $5, placed a sticker with my FAA assigned tail number on the drone.'
This is a puzzling post. Firstly because the CAA, the actual regulatory authority in the UK would not care one jot about you having your aircraft registered with the FAA, because the FAA has no jurisdiction in the UK.
You could have flown up to 1642 feet above where you took off from, and given the highest bit of mountain is Ben Nevis at 4,409 feet, there are plenty of other mountains lower down to look at.
Then there is the issue that the CAA have their own regulations about the maximum altitude you can fly in the UK, and it is a lot less than the 1642 feet your aircraft is limited to. Further, many places in Scotland are designated low flying areas for training by the Royal Air Force, did you check out if you were in one of those? All in all you demonstrated a complete lack of knowledge of local laws.
