DJI-Adela
Formatting SD cards is usually required to make them compatible with the device that they will be used with. We would advise you to format the SD card in the DJI GO App.
If you'd like to format it with your own PC, please format it as FAT32, cluster size 32KB for a card with capacity of smaller than 32GB, and exFAT, cluster size 128KB for a card with capacity of larger than 32GB.
Please note that if you don't format the SD card with the proper cluster size, you may be reminded constantly to format it, or SD card will reject to record the video, or other abnormal appearances may happen. |
