dobmatt
Flight distance : 1831050 ft
So, I bought this monstrous power supply. It's so heavy that - if it happen to be a mistake - it will work as a anchor for my boat . The idea is to be able to charge 4 Inspire or 4 Phantom batteries using DJI charging hubs, since I fly both birds. This should be possible because the power supply sports adjustable voltage output. Of course 1200 W/50A of available power on main terminals is way, way too much for DJI batteries to handle during charging. Thankfully the unit is equipped with 10A max outputs as well. This seems still just a hair too much, so - I believe - I have to find the way to dampen delivered amperage a bit to comply with batteries brains. I'm thinking about plugging the renowned Watt's Up meter in-line on output to make absolutely sure that the supplied voltage and current is within requirements.
Any suggestions before I wire everything and push the power switch will be greatly appreciated.
