What happens if you fly below takeoff height?
1231 6 2016-3-3
Ribfeast
Does anyone know what happens if you fly below takeoff height?
Eg if I stand on top of a hill, then fly it down the side of the hill into the valley below?  Would the motors shut off, thinking it is trying to land as it is below the height it took off from?
2016-3-3
Donnie
Flight distance : 3636782 ft
It will explode in Mid - Air causing untold death and destruction.................... for Gods sake Rib don't do it !!...............................  No nothing will shut off or anything.  It will just show negative numbers though.  Your initial home point will be the 0 reading anything below will be negative numbers above of course positive.
cheers ribfeast-donnie
2016-3-3
nigelw
Flight distance : 518084 ft
And RTH will still make the P3 ascend to the RTH height above the home point.  So, if you're flying at -80 metres & RTH height is set at 30 metres, it'll ascend 110 metres to +30 metres altitude from the home point.
2016-3-3
Ribfeast
What about if you flew towards a NFZ?  You know how the height restriction tapers down like an inverted cone the closer you get to it?  Would it theoretically allow you to fly higher in that taper-off area than you normally could?
2016-3-3
nigelw
Ribfeast Posted at 2016-3-3 23:11
What about if you flew towards a NFZ?  You know how the height restriction tapers down like an inver ...
Yes, because it doesn't know its height above sea level or the height of the airport above sea level.  It assumes you're at the same height as the airport.
2016-3-3
lalvar40
Flight distance : 168540 ft
No issue at all. Your phantom will not turn off. I usually fly from a top of a mountain. All works.
2016-3-6
Ribfeast
Good to know, thanks all
2016-3-6
