iCharlie
Flight distance : 770413 ft
I reckon the batteries will give you optimum life with consistent usage between 30-80% (in actual operating range) while storing them between 20-60% charge with a 2-5 day discharge programmed. This should give you a longer life and better performance times. Lithium loves to be exercised but not over used or over cooked. Storage of these batteries while at 100% will always be at a risk...there is a warning regarding fire/explosion in the instructions for good reason.
Best of luck,
C |
