Vote! Would you like separate P3 and P4 forums : Edited content
Rob_stal
Flight distance : 1243038 ft
Hi everyone, sorry about the copy cat post.
I only saw that this was already done a short while after I posted.
Please follow this link  (  http://forum.dji.com/thread-44362-1-1.html  ) in order to assist mjlstudios (first post) in getting accurate data.
Apologies and thanks
Rob.
Single SelectVote, Total 117 people participate in voting View Poll participants
Voting has ended
89.74% (105)
10.26% (12)
Your user group with no voting privileges
2016-3-4
DJI-Amy
I will wait to see the result.
2016-3-4
Rob_stal
DJI-Amy Posted at 2016-3-5 18:39
should be interesting
2016-3-4
Rob_stal
I only just saw that this was already done a good 16hrs before I did it.
I don't know if I should leave it here or remove it (if that's possible).
2016-3-5
Northofthe49th
Rob_stal Posted at 2016-3-5 16:17
I don't know if I should le ...
You can go under advanced and delete the post, maybe not the thread...
2016-3-5
Northofthe49th
DJI-Amy Posted at 2016-3-5 15:39
See here for results,
10:1 says this new layout stinks....{:3_56:}
2016-3-5
mjlstudios
Flight distance : 1540131 ft
DJI-Amy Posted at 2016-3-5 02:39
Hey Amy!
I posted this thread yesterday, you see what the results are there so far!
2016-3-5
DJI-Amy
mjlstudios@yaho Posted at 2016-3-5 17:27
Hey Amy!
http://forum.d ...
Oh, I see, we will consider it. Thanks.
2016-3-5
Northofthe49th
DJI-Amy Posted at 2016-3-5 17:31
Amy,
At least give a consideration to categories as below,
And one other thing, have DJI ever thought about consulting thier clients that actually use these sites regularly for their feedback? It might help!
2016-3-5
DJI-Dave
DJI-Amy Posted at 2016-3-5 01:31
Amy, it really needs to go back to the way it was.
Dave
2016-3-5
GTDrone
Flight distance : 2197703 ft
Guatemala
DJI-Dave Posted at 2016-3-5 13:33
I'm agree !!!
2016-3-5
delignejose
Flight distance : 1093248 ft
unbelieveble  dji already starts to put older phantom  aside lol
2016-3-5
Cessna172
艾米,
这是非常糟糕的主意。
请所有的舒适和享受请不要为DJI -戴夫说,并改回。
谢谢
2016-3-5
Northofthe49th
Cessna172 Posted at 2016-3-6 10:38
艾米,
这是非常糟糕的主意。
Amy, What he said..
2016-3-5
Cessna172
The problem here is that if Amy did not do a backup of the database before merging the forums.....seperation may be virtually impossible.
I'm not sure exactly what structure or data format this forum uses but in most cases, it is extremely difficult to undo this process.
At best, she "might" be able to restore it to where it was on the day she made the change....but all posts made since then might be lost.
That could be why she hasn't responded.   Trying to figure out if it's possible.This appears to be a proprietary forum build as far as I can tell.   If it is, it's highly unlikely the coders built in a way to undo the merge.  I do  know that if there is no UNDO for the merge built in, the longer Amy waits the worse it will be because the more posts that will be lost.
But to be honest' I can't be sure in any event.   Maybe this is ZenForum or vBulletin underneath and can be reverted.   I guess we'll see.
It is...but not very easy.
2016-3-6
