Phantom lights are red
3231 16 2016-3-5
Mr Lou Lar
my phantom lights won't come of red and I don't know why. Gimbal works , controller is connected , when looking in Dji go the gps works as there are satellites , motors work.
Please can some help I have only had it for 4 weeks and haven't crashed it once
There is also no beeping , when controller connected just red front lights
2016-3-5
Northofthe49th
Have you checked your manual?
You can find it here...http://www.dji.com/product/phantom-3-adv/info#downloads
2016-3-5
Mr Lou Lar
Northofthe49th Posted at 2016-3-5 18:01
You can find it here...http://www.dji.com/product/phantom-3-adv/info# ...
A critical error, what could it be ?
2016-3-5
Kneepuck
Flight distance : 275105 ft
you could try calibrating your imu.
2016-3-5
Mr Lou Lar
Kneepuck Posted at 2016-3-5 18:15
IMU Calibration didn't work , however S2 is not working ! I don't know if this is not In the air or it is the problemDji Go says everything is normal !
2016-3-5
Kneepuck
Well, thats a tough one.   The only time I get solid red is if the battery is seconds from dying.
2016-3-5
Kneepuck
I just noticed,  you said red FRONT lights.   The front lights are supposed to be solid red,  unless you turn them off.  It is the back lights that indicate aircraft status.  What are the back ( status) lights displaying?The s2 switch function depends on your model Phantom.  What model do you have?
2016-3-5
terrylewis
Flight distance : 3517287 ft
Mr. Lou Lar,
The Front LEDs show the orientation of the aircraft. The Front LEDs always glow solid red when the aircraft is turned on to indicate the front (or nose) of the aircraft. The front LEDs can be turned off in the GO App if you don't want them reflecting into videos.
The Aircraft Status Indicators are the Rear LEDs and communicate the system status of the flight controller. The table in Northofthe49th's post show the Rear LED status. Are you saying that the Rear LEDs are solid red?
2016-3-5
Mr Lou Lar
terrylewis Posted at 2016-3-5 19:35
Mr. Lou Lar,
The Front LEDs show the orientation of the aircraft. The Front LEDs always glow solid r ...
Yes it is the front LEDS , I am such a dong ! I deeply apologise for wasting your time .
It was because I panicked ... At first the camera didn't work , (I switched device and it did ) and then thought RED.
By the way I have a standard !
I am so so so so so so so so so x100 sorry ... I feel so bad
2016-3-5
Kneepuck
Mr Lou Lar Posted at 2016-3-5 11:39
It was  ...
Ok.  But,  here is a suggestion.  You should get very familiar with the manual on your phantom.  The last thing you want to do is panic in a real emergency.    There are posts on this forum on just about every problem it is possible to have.  Spend some time looking at those.  I would hate to see you end up crashing your brand new P3 because of something that is easily prevented.
Take care and have fun.
2016-3-5
Mr Lou Lar
Kneepuck Posted at 2016-3-5 19:53
Ok.  But,  here is a suggestion.  You should get very familiar with the manual on your phantom.  T ...
I'll go over them again now to be sure. However my dad actually create an emergency on my first flight !
He wanted to test so he held it while it put it down and changed all the fail safe settings and turned the controller off lol. But it did help
2016-3-5
Northofthe49th
Mr Lou Lar Posted at 2016-3-6 03:39
It was  ...
Ding Dong!...LOL
Thanks for at least acknowledging what the issue was/was not as it were..
Don't panic, not worth it, accident waiting to happen and crashing these are expensive..
Highly recommend these....http://forum.dji.com/forum.php?m ... mp;page=1#pid251592
seriously worth it....
2016-3-5
terrylewis
It was  ...
That's what the forums are for! Every learning experience help us to fly safely! Looking forward to your photos and videos. Best of luck and pilot safely.
2016-3-5
mjlstudios
Flight distance : 1540131 ft
The lights on the front of the Phantom are red, and stay red unless you turn them off. The lights on the back should flash green.
2016-3-5
Donnie
Flight distance : 3636782 ft
     At least you had the bollocks to admit it.  I say Good on You Mate!
Cheers with a Pint in your Direction,East and slight North for me- Donnie
2016-3-5
djiuser_PV2X5bL
Had a motor issue after checking found black paint flecks in and around the bearings ,my question is if u had a bad connection would the REAR LIGHTS STAY RED AFTER A FEW COLOR CHANGING SEQUENCS
2017-10-4
ALABAMA
Flight distance : 10442687 ft
djiuser_PV2X5bL Posted at 2017-10-4 06:14
If the rear lights are red, the motors won't even spin up.
2017-10-4
