edducati
Flight distance : 63507 ft
New Zealand
Yes on GH4. I have IMU led on gimbal but no light at HD/AV on gimbal. Not green, not red, no light at all at HD/AV. I have camera on, I can change switch from AV to HD and still no light.
I am just trying to get any video signal on DJI Go app from either HDMI or EXT.
On LB2, I changed my video resolution on my GoPro to 1080p30 and now I have two green lights on LB2 when I switch on GoPro, but still on DJI Go App I have no video. Setting I can change to 100% EXT priority from Gimbal or 100% LB priority from LB. No video no matter how I set Go App settings. Even tried 50/50% priority.
Is it possible that because I have issue at Gimbal HD/AV that it is killing video of LB2? As an example, no video light on HD/AV could mean that their is a short circuit inside with the PCBA, and that short circuit is transferring to LB2 through the gimbal cable and causing video not to work on the LB2?
Maybe I will try to disconnect gimbal cable from LB2 ajnd then see if I can get video from GoPro at hdmi port of LB2 only... |
