Donnie
Flight distance : 3636782 ft
Perhaps damaged unit , ( not in Atti mode are you?) You say you have calibrated every-thing . Including RC ? Any hard landings ?
Change your props( warped or damaged ) perhaps, I am reaching here I know ...... Make sure that ( Dont " check" do full IMU calibration ) IMU calibration is done on a dead flat surface and dont even breath on it during calibration. Check the gyro Settings also while stationary see if there way off. . Make sure gear is all the way Up. Not Flying with gear down are you? See how much play is in the landing gear struts, a little is ok but Not sloppy. Make sure compass calibration is done with NO METAL, not even change in pocket. Do it once correctly in the area you fly, preferably in wide open field. Then only re-calibrate when you travel over 100 miles.
Check you gyroscopic, acceleration and Compass settings by placing the aircraft on dead level surface like you are going to do IMU full calibration, look at all the settings and write them down, Now take and move the aircraft in the air like it was flying and then set it back down. Are the Gyroscopic, compass , acceleration settings settling back to the( Near)original settings?
Keep us posted, I would like to know if and when these get resolved .....or not
Cheers- donnie
