Another Osmo Panorama Issue
875 1 2016-3-16
Perchpole
Flight distance : 119810 ft
Hello, All -
My Osmo is behaving erratically when in Panorama mode. It keeps missing shots. For some reason this is almost always the shot which is 45 degrees to the right. The two images below demonstrate the problem perfectly.
Every other attempt to do a panorama (180, 360 or selfie) always results in the same problem.
My Osmo is using the latest firmware. My mobile devise is an iPhone 6+.
Edit: I should point out that when I say "missing shots" I mean the Osmo does not move to the next position in the sequence. It simply stays where it is and shoots from the same angle as the previous shot. This can be seen in the pics below.
Good
Good
Bad
Bad
2016-3-16
DJI-Adela
Hello!
Sorry about this issue. When it happens this problem, please reboot the Osmo and calibrate the gimbal. The problem has been reported to our engineers and will improve the performance in the next firmware update.
2016-3-16
