jimhare
Flight distance : 239035 ft
The OSMO is a fantastic addition to a short film, but I wouldn't recommend making one on it exclusively. It will best be suited for flowing establishing shots, walking/moving shots or other dynamic situations.
As for settings, yes, please see my tutorials listed in the above response. They are the same for both the Inspire and Osmo.
For the rest of your shots you will want another camera. If your budget is limited then look at a DSLR.
Also, you should record your sound separately, not directly into the OSMO. You can use it's audio for reference but you won't want it for the final.
Run lapel mics or a boom mic either into a dedicated sound recorder, or in a pinch, into your fixed camera. Again, for best results, don't use audio from the OSMO.
Hope this helps.
