DJI-Ken
![](https://forum44.djicdn.com/data/attachment/common/c7/common_16_usergroup_icon.png) DJI team
Flight distance : 1515312 ft
The sensors in the aircraft monitor almost every part of it. If you see the gimbal vibrating some, then it could be because of a prop.
Have you ever dinked a prop on the ground or anything at all?
'm betting that when you fly with new props you will not get the message anymore as long as you said the motors spun free and you didn't feel any resistance.
Also, if you ever fly from dirt, you should blow out the motors and the aircraft with some low pressure compressed air. |
