A2 + DJI S1000 sensors
1238 3 2016-3-10
r.velthuis
Hi Guys,
I need some information regarding the sensors the A2/S1000 uses.
Can someone tell me what sensors the S1000/A2 uses to keep:
Leveld
keep Altitude (so it nows when it almost at the ground)
and other sensors
And does the S1000 have these sensors or does the A2 IMU regulates it ?
If you check for example the Phantom 3, you can see the sensor at the bottom.
So what i need is the specs of al the sensors since i cant find it in the manual.
Thank you
Ron
2016-3-10
sanchezrenato
Flight distance : 1650735 ft
Hey Ron, the s1000 does not have those sensors. The A2 controls the height and all the parameters.
2016-3-10
DJI-Adela
The IMU in A2 contains Gyroscope, Accelerometer and Barometer.
2016-3-11
flaviomjr
Correct IMU takes care of those things
2016-3-19
