Ronin M making loud beeping noise
7478 11 2016-3-10
torjus.thesen
Norway
My Ronin M is making a really loud beeping noise when i turn it on and whenever its stabilizing. Has anyone experienced this?
2016-3-10
DJI-Adela
Hi,
Could you tell where the sound comes from? Did any indicator blink abnormally? Can you control the gimbal correctly?
More details about the issue will be appreciated!
2016-3-10
torjus.thesen
Norway
The sound seems to be coming from one of the engines – I think the vertical one. But it's sort of hard to tell. No indicators are blinking abnormally. Otherwise the gimbal is working just fine. The sound also disappears in silent mode. I understand that there will be some sound when it's not in silent mode, but it's really too loud to be functioning properly.
2016-3-13
DJI-Adela
By enabling Silent Mode, it can reduce the level of noise created by the motors. So, the noise should come from the motors. Please make sure there is no obstructions in the rotors. Check the setting of stiffness in the Assistant software please. Otherwise, it might be physical issue.
Since the noise from the motors will not be like beeping sound usually but slight constant buzz, to be sure about the problem, could you please send us the video for our better understanding?
2016-3-14
torjus.thesen
Norway
DJI-Adela Posted at 2016-3-14 10:47
By enabling Silent Mode, it can reduce the level of noise created by the motors. So, the noise shoul ...
2016-3-15
DJI-Adela
Thanks for your video!
I can see that you've turned on the Briefcase Mode, but your Ronin-M is still under Underslung mode. The noise sounds like the strong stiffness or the strong friction among the motors. Please hold the Ronin-M in a right way and have a test.To enter briefcase mode, rotate the handle bar 90 degrees so that it is perpendicular to the ground. You may turn briefcase mode off in the gimbal App, in which case the Ronin-M will never automatically transform into briefcase mode.
Wait for your further update.
2016-3-15
torjus.thesen
Norway
Okay, I understand. I turned briefcase mode off, and it had no effect (on the beeping noise). I've also tried different stiffness settings and have had no luck with that either.
2016-3-16
DJI-Adela
Everything seems to be OK but the motors. Are you sure you've balanced your camera well enough before powering on the Ronin-M. Here is the tutorial video for balancing the Ronin-M, could you please check it again?
http://www.dji.com/product/ronin-m/info#video
If you are operating it correctly, but the problem still can't be fixed, I'd advise to return it for our professional test.
I'll wait for your update.
2016-3-16
torjus.thesen
Norway
I'm pretty sure I've balanced it properly, yes. How do I go about sending it in?
2016-3-30
DJI-Adela
torjus.thesen@g Posted at 2016-3-31 02:47
If you're located in UK, please contact support.eu@dji.com for further assistance.
For more details about DJI GENERAL AFTER-SALES SERVICE FLOW, please visit DJI official website at http://www.dji.com/service
2016-3-30
Ilja-L
Hi, I've got the same problem with my Ronin, can you tell me the outcome of your problem?  Is it's a physical problem? Did you send it in? Or could it be solved by software/settings/firmware? Thanks in advance, Ilja
2017-10-30
TracyCox
I have with the Ronin S gimbal... I'm wondering if it's because it never holds the settings so the motors aren't set to strong and I'm way off balance with my zoom lens... yes -I use a zoom on a gimbal :-(
2018-9-10
