Davidaw
Russia
I had the same thought but I didn't go through the Forum until after I'd bought it!
I haven't used mine in anger yet but I have done a lot of practice "playing" and I have yet to experience any of the problems I've read about - maybe I'm lucky, maybe I will see them, who knows?
First of all it depends what you plan to use it for - a lot of stuff that GO-PROs are use for, like action cam stuff, often don't need stabilising - the wide angle, close to the action , cinema verite "wobbles" tend to work well.
From what I can determine, there are a few issues and bugs but a lot of the time I read about problems that are really born of using a camera beyond what it's meant for - mounting it on a tripod and wanting it to keep perfectly still - why buy or use a stabilised camera for that? Just use a regular camera on a tripod for a still/static shot!
Audio - I bought it knowing full well that the audio isn't great but it's no worse than the go pro and again - for real production work - I have a master recorder and simply post sync everything so - poor quality (or reference only as I think of it) audio isn't an issue.
So my summarised thinking is that pro video cameras (I've used hundreds of them) come in all shapes and prices and by pro standards, the Osmo is not expensive, I've used multi thousand dollar/pound cameras and haven't found one yet that doesn't have limitations of one kind or another.
So should you buy? If it's going to be your only camera - absolutely not, you'll be asking too much of it and will be disappointed with the results. If you're using it as a second camera to use for certain effects to fill in and make up for what 'camera A' can't do - then go for it.
It's good, it's clever it's even fun to use but it's not ideal for every situation if you plan to use it to enhance video work with an extra dimension then it's ideal.
That's not to say that it doesn't have a few issues - it's new of course it does but DJI seem to be working through that and I suspect Osmo 2 will be even better! If you're happy with your go pro, why change now? If you want to augment what and how you shoot - then go for it just don't expect too much, use it within it's limitations and it's amazing, try to exceed those and you'll be a sad little camper!
So far - notwithstanding the issues - slow wifi connection, picture lags behind, conventional camera moves (where you don't want it to compensate) are hard to learn but not impossible, battery life is a major downer but plan round it. - I'm really happy with it (so far)
Just my newbie view!
