Lightbridge - Software freezing after connecting HDMI
1254 10 2016-3-12
nikolaospaschal
Flight distance : 3093517 ft
Dear all .
I use lightbridge with A2 om my s1000.
Software and live video is coming perfect when i use the app, but when i connect my blackpearl with external HDMI cable the app is freezing and i have no video at both screens...
Any idea please ?
2016-3-12
DJI-Adela
Hi,
Lightbridge doesn't support an external signal output at the same time and obviously your blackpearl influences the original output.
2016-3-14
nikolaospaschal
Greece
DJI-Adela Posted at 2016-3-14 10:39
Hi,
Lightbridge doesn't support an external signal output at the same time and obviously your blackp ...
And what is the use of the HDMI port please ?
2016-3-14
nikolaospaschal
Greece
Hi,
2016-3-14
DJI-Adela
nikolaospaschal Posted at 2016-3-15 02:00
Hello!
Please refer to page 9 of the Lightbridge Quick Start Guide in this webpage: http://dl.djicdn.com/downloads/l ... art_Guide_v1.06.pdf
You'll find that it states that the USB and HDMI output are mutually exclusive, the HDMI output overrides the USB output. If you use them at the same time, they may influence each other.
2016-3-14
nikolaospaschal
Greece
Yes but when i start only with HDMI i got no signal in Blackpearl screen...
2016-3-14
DJI-Adela
Please check the HDMI cable and its connection. Can the USB port still work well separately?
2016-3-14
nikolaospaschal
Yes USB and Lightbridge app ia ok . HDMI NOT!!!
2016-3-15
DJI-Adela
nikolaospaschal Posted at 2016-3-15 16:59
I see...
If all the connection and cables are correct and in good condition, it should have the HDMI output.
Please check video sourcing setting. Enter DJI Lightbridge setting menu, tap "Video Source Setting" and select "HDMI/AV" as video source.
2016-3-15
nikolaospaschal
Yeap it worked finally !!!
Thanks
2016-3-15
DJI-Adela
nikolaospaschal Posted at 2016-3-16 00:21
Thanks
I'm glad to hear that, thanks for your positive feedback!
2016-3-15
