Donnie
Flight distance : 3636782 ft
I agree once you master takoff and landing, remove them. Now the IMU calibration, you dont have to FREEZE your aircraft, If it is cool climate where you live place it outside. Just cool it down a-bit. this will help the wait time in cold weather. Most important make suer you are on a perfectly level surface, You can just use a bubble to check. During the calibration, stay away from it because the bounce in the floor can effect it. Only took mine about 10 min tops. Also when you do your Compass calibration do it in a wide open area away from metal, make sure transmitter is at least 10 feet away as well and no metal on your person, not even keys or change in pocket, do it right one time. When you do the compass and IMU calibration correctly dont keep doing them. Only after a frimware update or a significant (Over 100 miles) change from the original calibration. Do it right once and leave it alone. If you notice drifting and a hard landing would be a reason to re-calibrate as well.
Hope this helps.............- donnie If you have the standard , save up for an advance or pro, they are very impressive! |
