Turning off the Inspire while recording...
1588 8 2015-1-9
Ozren
Croatia
Well, turning off the Inspire while recording makes a corrupt .mov file. I think that can be fixed in software, to stop recording if Inspire 1 is turning off.
Just a suggestion.
Thanks.
2015-1-9
DJI-ZT
Flight distance : 411411 ft
China
Tip:  keep the SD card in camera and turn on the inspire 1. The corrupt file will be fixed in seconds.
Thanks for your advice. I think we have done the function as what you said. There must be some bugs. We will check that.
2015-1-9
rbendjebar
Flight distance : 3170190 ft
In order to turn off the Inspire, it would have to not be flying, right. Why would you be recording while on the ground? Seems like a non-issue. Pretty much all cameras will corrupt a file if turned off in the middle of a write sequence.
2015-1-9
Ozren
Croatia
DJI-ZT Posted at 2015-1-10 02:11
Tip:  keep the SD card in camera and turn on the inspire 1. The corrupt file will be fixed in second ...
Thanks DJI-ZT
2015-1-9
T J Gilbert
Flight distance : 74659 ft
This condition presents itself with the Vision series as well...
Turning the camera back on usually fixes it.
2015-1-9
abe
Flight distance : 524032 ft
rbendjebar Posted at 2015-1-10 02:28
In order to turn off the Inspire, it would have to not be flying, right. Why would you be recording  ...
It's quite common to forget to stop recording after landing, and then turn off the aircraft while camera is still running. The solution to simply turn on the Inspire again and have it correct the issue is a good one..
2015-1-9
Ozren
Croatia
I dont have the Vision ( have phantom 2 h3-3d), but the Inspire 1 has a turn off cycle that lasts for a sec or two, i know the software can stop any current recordings and write the file, then turn off the Inspire.
2015-1-9
pgphotoyou
Flight distance : 4163862 ft
I put the SD card back into inspire one it did not fix the problem, I see no video there I haven't done anything with the card, I didn't immediately add another three second video, is there another way to get this video I have all of the latest updates as of June 1 2015 I did however put in a different card and start recording but the card that Has the missing video on it I have not removed anything from it, is there anything else I can do?
2015-6-1
chris
Flight distance : 242247 ft
As with any recording devise whether its audio or video when you power off before stopping the record it will not write the end file info.
2015-6-1
