Critically low battery voltage warning!
960 8 2016-3-13
jleech37
Hello,
Today for the first time i had the critical low battery voltage warning appear and it brought my phantom down into some ferns and luckily did not do any damge, just dislodged a wire but was easily fixable. My battery was at 55% at the time and was wokring fine for about 5 min. When the phantom whnt into critical mode, the battery was at 45% roughly. Has anyone else experienced this issue and is it a problem with my battery? Below is a screenshot from HealthDrones.com. Is shows a major problem but im assuming this is the problem?
Thanks
Jamie
2016-3-13
[RCG]Balthazar
Flight distance : 475371 ft
Norway
Yea common problem from before firmware 1.6 improved the balance charging. Please check if your batteries are updated and do a full cycle.
2016-3-13
jleech37
Thanks for the reply, When you say a full cycle what does that fully mean. Charge to 100%? The update will flag up in the app wont it if they are not updated?
2016-3-13
joshharries.out
Hi Jamie, I think he means let it go to 0% then fully charge again.
2016-3-13
Geebax
Unfortunately the HealthyDrones page does not tell you much at all, it is just listing a minor cell deviation, not even a major one. What would have been more interesting is to see the battery voltage readout on the screen at the time it happened.
2016-3-13
jleech37
Im assuming there would be no way to check this?
2016-3-13
Geebax
jleech37@outloo Posted at 2016-3-14 09:35
Not unless you were recording the screen output at the time.
2016-3-13
DJI-Amy
Hi, please try to fully charge the battery, and then try to upgrade to the latest firmware.
2016-3-13
Cetaman
Flight distance : 2387785 ft
jleech37@outloo Posted at 2016-3-13 12:35
Aloha Jaime,
     Try read my post from a week ago.  Does any of this apply?  Looks like the same thing to me just different numbers.  You got it worse!
http://forum.dji.com/thread-44614-1-1.html
Aloha and Drone On!
2016-3-14
