Phantomflyer
Flight distance : 1016486 ft
I'm still in the experimentation phase of using the Osmo, and received some great advise so far, so I'm not about to sound like I know WTH I'm speaking about. Having said that, I don't believe I've seen much of the horizon drift issue with my used Osmo, and that MAY be because the camera is still loaded with an older F/W version 1.0.1.19, can't say for certain at this point. However, with that being said, I was wondering if anyone had tried using the camera in the Flashlight mode to determine if you get the same effect.
Again, I realize this may not change anything, and is certainly not a fix, but something that may help reduce the frustration level when using the camera.
If you like, check it out and please let us know if it's helped any. : )
Regards, |
