youngphoto
I had an issue with the tilt when I first calibrated the RC with the RC Assistant. (P2V+ 3.0, Mac) When I was doing the initial calibration I moved the two sticks through their range of motion, but I DIDN'T move the tilt wheel. When I then switched to the Phantom Assistant, and activated NAZA (I recommend doing this from the beginning.) the camera tilt didn't work from the dial on the RC. To fix it, I hooked up the RC to the RC assistant again, and redid calibration this time MAKING SURE TO MOVE CAMERA TILT WHEEL THROUGH FULL RANGE OF MOTION. After finishing the calibration and then doing Phantom Assistant again the camera tilt worked fine. (Be sure to remove the gimbal lock.. I have to get a remove before flight flag for that thing, I've turned it on before removing the gimbal lock a few times on accident.) Good luck, hope this helps. |
