Geebax
If you go into the settings for the video camera section, it is possible to alter all manner of settings. As some have suggested, you can use a Neutral Density filter on the front of the lens. There are a range of 3 filters available from DJI, and also from other suppliers. But you will need to understand how these are used, and it is too complex a subject for me to go into here. Look under the tutorial section on the front page of this forum for material. You can also set the camera to allow manual control over exposure, using the wheel control on your RC unit. This of course requires you to know what you are doing as well, so DJI provide a display called a histogram to help to set the correct exposure. |
