Geebax
No, because the feed to both the Advanced and Pro is essentially the same, 720p. The only difference between the two is the bit rate, meaning the Pro has a slightly higher bit rate and there it has less compression artefacts. And swapping one camera for the other will not work because there is more to it than that, the Lightbridge system is also different. |
