AG0N-Gary
Flight distance : 700846 ft
What does it say when you fully charge it? If charging it fully doesn't bring it back, I would do a calibrate procedure on it to see if it recovers. Fly it to run the battery down. Fly until it is a little above critical and land immediately (before it gets to critical). Shut the motors down and remove the props for safety. Turn it on again without starting the motors and let it run until it turns itself off. Then pull the battery and let it cool down. When it is cool, fully charge it again. See what the life says at that point. I wouldn't recommend this procedure be done often, but I've seen it recommended here on the forums. I did both of mine today. Run it down to 10% or so normally and then fully charge it. Mine sat for a month without flying recently. Both batteries showed shortened life expectancy. I ran them down a few ten percent and then recharged them. They have shown 100% life since then. |
