Phantom 4 Collision Avoidance Test #020
2063 15 2016-3-16
jsouders
Jeff test his Phantom 4 collision avoidance system by flying directly at him!!!
Do not try this at home!
Jeff test the Phantom 4 new firmware version 01.01.0301 on Collision Avoidance.
2016-3-16
QuadBart
Flight distance : 256506 ft
I've seen plenty of demos of the CA system while at the hands of the pilot doing a manual flight towards an object, I would like to see what it does if you put a building/object between you and the bird while in RTH mode.  I would like to see what it does.  Does it actually try to find a way around the object to get home?
2016-3-16
Jkeller84
Flight distance : 396955 ft
QuadBart Posted at 2016-3-16 18:40
I've seen plenty of demos of the CA system while at the hands of the pilot doing a manual flight tow ...
Don't quote me on this, but I think I read somewhere that the collision avoidance is not active in emergency RTH
2016-3-16
Skyrider
Banned
2016-3-16
david.p.mann
Flight distance : 18669501 ft
Jeff,
Thanks for testing this important new safety feature on yourself as a human test dummy - now I don't have to do it! Ha!  I had to laugh when you were visibly (and understandably) more jumpy during Test #5 after Test #4 failed because you were in S mode.
2016-3-16
microcyb
Flight distance : 1095955 ft
Spell check at end of video. Word great?  But hey seriously great video.
2016-3-16
DJI-Amy
QuadBart Posted at 2016-3-17 09:40
Don't worry, it will ascend and pass the obstacle, if there is not enough power for it to pass and return home, it will initiate the low power landing, the front vision avoidance system still work when RTH.
2016-3-16
DJI-Amy
Jkeller84 Posted at 2016-3-17 09:45
Don't quote me on this, but I think I read somewhere that the collision avoidance is not active in ...
It will ascend and pass the obstacle, if there is not enough power for it to pass and return home, it will initiate the low power landing, the front vision avoidance system still work when RTH.
2016-3-16
DJI-Amy
Although the avoidance system is reliable under appropriate condition, I still suggest you don't fly it towards to people directly.
2016-3-16
Jkeller84
DJI-Amy Posted at 2016-3-16 23:42
It will ascend and pass the obstacle, if there is not enough power for it to pass and return home, ...
Thank you for correcting me on that
2016-3-16
grangerfx
Flight distance : 817713 ft
The P4 dips right after it stops. I have seen this in most of the collision avoidance test videos. What happens if the drone is very close to the ground? My guess is that it is fine due to ground effect and/or the down sensors but it would be nice to know.
2016-3-16
Mike_fnq
Flight distance : 5623 ft
QuadBart Posted at 2016-3-17 11:40
It climbs to avoid, the only caveat I saw was that it won't exceed the altitude limit (I'm not sure if this is the set limit or the 500m absolute limit).
2016-3-16
Highlander Brow
Good video Mike! It is really scary but it worked. It is obvious that in some fparticular scenarios, the 500 m limitation may cause a trouble. In your case, you were like that the P4 following the straight line to home did not have to climb above 500 m to pass those threes.
2016-3-17
ArtistFirst
Flight distance : 986716 ft
It will fly OVER a building not around. If it's approaching an object in RTH it will ascend until it can clear ur.
2016-3-17
jsouders
I will do that test today the video will be posted tonight.
2016-3-17
LordNeo
Flight distance : 548212 ft
Chile
grangerfx@gmail Posted at 2016-3-17 03:24
The P4 dips right after it stops. I have seen this in most of the collision avoidance test videos. W ...
It has to do with the translational lift. I guess it doesn't compensate good enought when low in the ground to compensate both, the translational lift loss and the ground effect gain.
2016-3-17
