njabinc
I own one Inspire 1 PRO and one Inspire 1 PRO Black Edition. After reading the release notes and researching all available information on here, the service forums, and the many independent Inspire forums easily found on the internet I have updated to the PRO update provided on 11-24-15 which is 1.1.0.40. This firmware update had very little issues reported, provides the majority of functional features, avoids further limitation of power, doesn't display the well documented increases in shadow noise and contrast issues, and seems to be the firmware the aircraft is shipped with. I should add that later shipments may use later firmware. The other fact I've never seen discussed is that if one purchases a replacement flight controller whether for an Inspire 1 or a V2-PRO which encompasses every system on the aircraft barring the GPS and VPM it is received requiring every firmware update installed starting from 1-1-2015 (the next update after geofencing) although DJI has removed some of these from the download page though I still have them all. So if someone felt strongly about using prior firmware it is achievable though at considerable expense. Eventually the correct reset point on the aircraft flight control circuit board will be identified and it will be as simple as opening the enclosure and resetting the aircraft as mapping a board simply involves identifying the components attached, their manufacturers, this leads to technical data provided by those manufacturers which includes pin assignments, then it's a matter of spending the time tracing the connections combined with the application of the technical data. Although this won't provide any proprietary programming it will identify memory and system reset procedures and access points on the board. I'll bet reset will also allow an aircraft name change at that point also. |
