DJI Assistant2 - "Start Calibration" not possible
14091 34 2016-3-17
Thacyoon
Norway
Hi,
I just got my P4 today. Have updated all FW, calibrated the IMU's, gimbal and compass. All looks good so far. But, when I connect the P4 to my PC and launch DJI Assistant 2, and goto the 'Calibration' screen - the lower right button 'Start Calibration' is greyd out and the spinner wheel to the left of the button is just, well, spinning.
What is wrong?
2016-3-17
Craig Rogers
Flight distance : 168445 ft
I had the same issue too.
Lucky after a firmware upgrade I no longer get the calibration requried and all works ok.
Would still like to get it fixed for any future calibration.
2016-3-17
DJI-Ken
Flight distance : 1515312 ft
Make sure on PC to run as adminstrator. On Mac you have to make sure that the driver and dmg is installed correctly.
2016-3-18
boxerman
Flight distance : 39695 ft
Ken - have latest P4 firmware (0288) - have tried to perform calibration in OSX Assistant after installing the driver and app, but it will fail every time.  Have also tried running Assistant under Windows 10 as Administrator, but cannot select the Calibrate button.  Both with Assistant 2 v1.0.2.  I would like to see this work correctly.  Thanks.
2016-3-24
jwalker59
Flight distance : 37369 ft
DJI-Ken Posted at 2016-3-19 05:43
Make sure on PC to run as adminstrator. On Mac you have to make sure that the driver and dmg is inst ...
I have the same problem.  I can see firmware update status, but can't do calibration.  How do I see if drivers are installed properly?  I know I installed them.
2016-4-3
FatedFilmsNC
I am also unable to calibrate using DJI Assistant when connecting my P4. I can start calibration, but once i press start and follow the instructions on screen, it doesnt do anything. I tested this extensively last night.
2016-4-4
dprovince
Flight distance : 18307 ft
same issue for me.  did this get fixed for anyone?
2016-10-28
bdimarzio
Flight distance : 202585 ft
dprovince Posted at 2016-10-29 01:09
I can click on the calibrate screen but I get a screen size error.
2016-10-28
Snowwolfwarrior
Flight distance : 1064780 ft
I had this today but I restarted pc and P4 and worked ok after
2016-10-28
calls4u2
Flight distance : 211604 ft
Use the older assistant software, the new one doesn't seem to allow you to calibrate. It does speak 10 languages at once though if you turn the speakers up.
2016-10-28
Aardvark
Flight distance : 384432 ft
calls4u2 Posted at 2016-10-28 23:51
Use the older assistant software, the new one doesn't seem to allow you to calibrate. It does speak  ...
Just the newer version available for downloading now. I did manage to get it to work; after the initial 'corner' alignment hold quad steady at that position, you then need to chase the blueish rectangle round the screen tilting quad slightly to follow the rectangle (working from memory here )..
2016-10-28
calls4u2
I was lucky I had the old versions still here. The new one recognises the p4, but calibrating sensors just makes loads of noise and start button is greyed out, of that's how it was when this version is a first released anyway.
2016-10-29
Jason WAI
Flight distance : 3136201 ft
I had the same issue with Window 10  too but have it run on iMac.
The DJI Assistant 2
2016-10-29
calls4u2
I've one of the latest iMacs sitting in the corner gathering dust, if I need to calibrate again I'll power it up I suppose.
2016-10-30
kroogz
Flight distance : 820794 ft
Try a lower screen resolution like 1024. I found on my 4K screen it did not accept such a high resolution.
2016-10-30
Punchbuggy
Flight distance : 483166 ft
Yeah, there's something seriously wrong with the latest version of Assistant. I get the multiple voices and a blank screen when I start the calibration.
DJI, can you provide link back to previous version please. I'd like to calibrate my P4...
2016-10-30
makersmark
Flight distance : 2958264 ft
kroogz Posted at 2016-10-30 18:20
this is the fix
2017-1-1
SPRTBKRYDR
Flight distance : 3777011 ft
Maybe someone could link the older version so that we can try it??
2017-1-1
Andrew245
I have never done this sort of calibration what does it actually do ?, calibrating IMU and gimbal is not enough ? my P4 works perfectly, should I do that Assistant calibration ?
2017-1-1
SPRTBKRYDR
I say if it ain't broke don't fix it.
2017-1-1
Aardvark
Andrew245 Posted at 2017-1-1 13:40
It calibrates the lower and front visual sensors (and I believe, the ultrasonic transducer), which hopefully will help stabilise the aircraft below 10m altitude, and also mean it might not bump into things when moving forward.
I think it would be a good idea to read the manual a couple of times, it can be downloaded from Here. That is also a good bookmark to keep.
2017-1-1
PressPlay video
Bosnia and Herzegovina
Hi
I have Phantom 4
DJI Assistant 2 version 1.8.0
Why do I have to lean aircraft 35 degrees down when the calibration sensor?
When I get straight to the screen image is tilted about 35 degrees and then I have to lean aircraft.
Is it ok?
Thanks
I'm sorry for bad english
2017-1-3
freelanderuk
Flight distance : 177720 ft
Link to DJI ASSIST 1.0.7
https://dl.djicdn.com/downloads/ ... sistant+2+1.0.7.exe
Courtesy of  a post on Phantom Pilots by  Tylerjay24
2017-1-3
Aardvark
PressPlay video Posted at 2017-1-3 06:20
Hi
I have Phantom 4
Presumably your screen is slightly tilted ? And you are having to adjust the angle of the aircraft so that the sensor cameras are at a right angle to screen (Orthogonal).
If it is passing calibration then I'm sure all will be fine.
2017-1-3
SPRTBKRYDR
DJI-Ken Posted at 2016-3-18 13:43
Does not cure the problem
2017-1-3
DJI-Ken
Hi
I have Phantom 4
That is how the sensor calibration is done.
You start the calibration with the aircraft straight and your computer monitor straight, then during the calibration you tilt the aircraft and follow the boxes around the screen and not move the aircraft horizontally or vertically but only tilt it.Here is a tutorial video on sensor calibration.
2017-1-3
MartK
Flight distance : 516237 ft
Estonia
Make sure you dont use any screen adapters (Like HDMI-DVI or VGA-DVI) and make sure you are running your monitor on a native resolution (Dont upscale). Fixed it for me.
2017-1-3
PressPlay video
To pass calibration to 100% only what I need aircraft tilted 35 degrees downward.
I was flying after that and I had some problems I guess it's ok.
The only problem I have noticed is that if a problem is if it is in the air less than one meter on the downhill I wish to and have to correct the bat up.
2017-1-4
WEX
Poland
I have the same calibration problem. If I reduce the resolution to FHD, I can calibrate but I have a white calibration screen - there are missing dots. The cameras shown at the bottom left are stopped as if in the first frame after clicking the calibration button. Nothing is happening anymore.
In the second laptop computer I normally go into the calibration and see the calibration dots, I can calibrate but screams with a minimum screen size of 12.5 "and I have 12" so the calibration result goes wrong. When connect to TV 40" via HDMI so the result goes wrong too.
Unfortunately, I had to use 3 PCs at home and it was not until I managed to properly calibrate VPS.
2017-7-15
fans5fc592aa
Flight distance : 271234 ft
I too have never been able to calibrate VPS using Assistant 2, with my 27" iMac retina display. It won't work on the default 2560x1440, the calibration window is just blank, with red warning "incorrect alignment method.
There is no red box or green displayed. Tried it also on 1600x900 - same result.  Also tried it on external 30" Cinema Display, when I type in 30" it still shows "failed to check screen size"
I don't have access to a PC.
Why won't it work on a 27" iMac?
2017-9-1
fansa84fe8a4
Flight distance : 3 ft
Apple screen might be too glossy and stray flare hurting the calibration.  Try in a darker area out of any flare.  Might turn down the brightness too.
2017-9-1
ALABAMA
Flight distance : 10442687 ft
Why does everybody want to start "messing" with things on a brand new drone right out of the box?
Everything is already factory set and should be working perfectly.  It's asking for trouble.
Just activate it and take to the air.
2017-9-1
djiuser_szqFyCV
Flight distance : 2961880 ft
Japan
dJiAssistant2
2017-10-15
DavidMFranks
Flight distance : 14882 ft
Yep, my iMac won't display the calibration whatsoever. All I get is a blank white screen. No dots, no squares, nothing. This is incredibly frustrating. On the new iMacs it's not possible to dial down the screen res, either - so we are all stuck. Don\t suppose anyone has a Mac version of the older Assistant???
2017-11-15
Weeman
Flight distance : 2186506 ft
Found this link on google but don`t have a mac myself to test it
https://dl.djicdn.com/downloads/ ... ller_mac_v1.0.2.dmg
2017-11-15
