martin94b
As we were chatting about the "DJI Movie maker" tool in the TimeLapse thread, the suggested solution would help to solve this issue as well (but the lighting conditions in 120fps):
Load a HD @120fps movie into the Movie Maker, select the desired multiple factor (e.g. every 2nd frame [or 3rd or... 10th]), the tool then removes all frames in between and saves a new HD movie which would be the desired 60fps in this example. This way you speed up your SloMo just as you could speed up from regular to TimeLapse.
Again there is a big benefit for the user (just as in TimeLapse use case): you first record in "fullest framerate" and can adjust / finetune the result later in Post Production so it perfectly fits your timing needs. Sometimes you just don´t know what framerate will fit best already upfront during recording...
DJI, are you listening?
Made that suggestion several times already but no response yet... |
