P3 Advanced Camera Lens
1310 18 2016-3-17
dustinjohn2
Hey guys!  is the P3 Advanced camera lens supposed to screw off so you can put filters on it?  or no?  mine doesn't seem to screw off?  (just got mine)
2016-3-17
nathan.schernec
Try harder?  It's on there pretty good.  I just unscrewed mine for the first time today and replaced with an ND filter.
2016-3-17
dustinjohn2
nathan.schernec Posted at 2016-3-18 11:24
Try harder?  It's on there pretty good.  I just unscrewed mine for the first time today and replaced ...
wow really?  my advanced is brand new.. i don't want to break the gimbal.. I put some pretty good elbow grease into it
2016-3-17
mrGREEK360
Flight distance : 236414 ft
If you see a crease around the filter then it screws off. Use blue rubberd disposable workshop gloves that auto mechanics use as that gives you the grip and leverage needed. Keep the camera steady with (make sure it doesn't move much) left hand and twist the filter  counter clockwise as hard as you can.  Don't bother with rubber bands as some suggest, get grippy gloves.
All p3a have removable filters.
2016-3-17
leorvasquez
I have a P3 Adv and wanted to try a new ND filter. It took me a few times to figure out that I was probably squeezing too hard and not trying to turn it as much.  Remember the lens cap or ring is made of aluminum and can respond to the slightest amount of pressure around the threads. Just keep using your fingers and not your hand to turn it loose and then it will start to give a little and then loosen right up. :-)
2016-3-17
DJI-Ken
Flight distance : 1515312 ft
Easiest way is to grip it with three fingers evenly spaced and don't press too hard, then untwist. It will come off, the harder you squeeze the harder it will be to come off.
2016-3-17
dustinjohn2
DJI-Ken Posted at 2016-3-18 12:13
Easiest way is to grip it with three fingers evenly spaced and don't press too hard, then untwist. I ...
oh wow    lol  ok  i will try
2016-3-17
dustinjohn2
lol  really?  ok i will try
2016-3-17
ArcticM39
The way I removed the UV cover is put to on a latex glove first before attempting to turn the very delicate UV cover.
Do not use excessive force. Good grip and gentle force will turn it.
2016-3-17
dustinjohn2
ArcticM39 Posted at 2016-3-18 13:23
The way I removed the UV cover is put to on a latex glove first before attempting to turn the very d ...
thank you very much.. I will continue to try guys.. appreciate it alot...  it will come loose eventually.  great advice
2016-3-17
DJI-Ken
dustinjohn2 Posted at 2016-3-18 13:25
thank you very much.. I will continue to try guys.. appreciate it alot...  it will come loose even ...
Were you able to remove it?
Also a zip tie may help too.When you do get it off, make sure not to lose the rubber o-ring in the lens cover.
2016-3-18
dustinjohn2
DJI-Ken Posted at 2016-3-18 22:17
Also a zip tie may help too.When you do get it off, make sure not to lo ...
I haven't gotten it off yet, Ken!!!  lol.. it's the darndest thing!!!!   I'll figure it out eventually.  Are the Threads on it American, the usual "righty-tighty; lefty-loosy"???  I was wondering if I was turning it the wrong way?
2016-3-18
DJI-Ken
dustinjohn2 Posted at 2016-3-18 23:09
I haven't gotten it off yet, Ken!!!  lol.. it's the darndest thing!!!!   I'll figure it out eventu ...
Yes, righty tighty lefty loosy.
But they are very fine threads. It will come off, just make sure not to squeeze too hard.
2016-3-18
dustinjohn2
DJI-Ken Posted at 2016-3-18 23:50
But they are very fine threads. It will come off, just make sure n ...
I trust u.  It sure is strange, because no matter what I do, it won't budge.  but no fear.. I get some rubber grip on it pretty soon.. I"m on my lunch break now
2016-3-18
DJI-Ken
dustinjohn2 Posted at 2016-3-19 01:27
I trust u.  It sure is strange, because no matter what I do, it won't budge.  but no fear.. I get  ...
Reaction to when something won't come off is is to squeeze harder. But in this case it makes it worse.
I promise, you'll get it. squeeze lightly but untwist firmly.
Ans as mentioned before, a latex glove will help.
2016-3-18
aopisa
Flight distance : 430686 ft
Try putting a rubber band around it to help with your grip. Easy does it.
2016-3-18
dustinjohn2
aopisa Posted at 2016-3-19 03:40
thx   will try
2016-3-18
AG0N-Gary
Flight distance : 700846 ft
Wide rubber band, very loose grip.  Turn left and don't loose the o-ring.
2016-3-18
JtrJr-UAV Pilot
Flight distance : 4341 ft
Dustin,
Check this thread: http://forum.dji.com/forum.php?m ... mp;extra=#pid348135
Jerry
2016-3-18
