Firmware update failed
f4leczka
Poland
Hi,
I've tried to update - Phantom 3 Adv, and when i've put 1.7 firmware, from few minutes after update start, Quad starts to DDDDDDDDDDD.
I've look @ logs .txt and i've seen this.
But, when I turn on Quad + RC and DJI GO, i can see in information that the Quad is up to date 1.70.0060 ?
What happend ? How i can rerun the update when Quad give me info that is up to date :/
RC got update via DJI GO and turn green after that
========== 2016.03.10 17:53:47 =====================
Packet: P3S_FW_V01.06.0040.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.07.0060.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Abort.
2016-3-18
f4leczka
Poland
Problem solved, I've downgrade Firmware to 1.6 and upgrade again to 1.7 and its works.
2016-3-18
digdat0
Flight distance : 11896378 ft
i had to do the same yesterday, except mine is a professional.
2016-3-18
delignejose
Flight distance : 1093248 ft
f4leczka  did you take out for a test flight
2016-3-18
DroneDad
How do I successfully downgrade? I have the same problem, and have tried formatting the SD card, yet when I try to install the previous version of the firmware 1.6 I get the log result -
I just spent a half hour with tech support somewhere overseas, and their final response was to contact the LA support office on Monday.
Not amused to say the least.
2016-3-18
f4leczka
Poland
DroneDad Posted at 2016-3-19 05:02
How do I successfully downgrade? I have the same problem, and have tried formatting the SD card, yet ...
Hi
I've just format SD Card, fresh SD Card with ony 1.6 Firmware BIN, power off/on P3 and everything works smooth during downgrade, after that i've only power off P3 delete 1.6 FW, upload 1.7 and turn ON the P3.
Update to 1.7 works fine this time.  Dont have time to do fly test, but i think everything is good
2016-3-21
