tracelink
South Africa
Hi Donnie
I used my Android tablet. When using Android you must enable the developer mode to get the USB to work with the controller.
I have the following apps that is used by the controller:
Go App from DJI
Litchi - Best app ever
Vertical Studio - Best follow POI function ever
Android will ask you, when you switch the controller on, what app to use. You get two options, Just once and Always. I selected the Always option for the Go App to make sure that it is always used when the controller is switched on.
Follow these steps, please read them carefully.
Step 1:
Make sure that everything is switched off except the phone and make sure that the Go App is not running in the background
Step 2:
Make sure the the Go App is the default app that will always start when the controller is switched on. (Read at the explanation above)
Step 3:
Press C1, C2, record and the wheel on the right side of the controller and then turn ON the controller and hold the buttons in until the Go App starts up. You can now let go of the buttons.
!! THIS STEP IS VERY IMPORTANT !!
Step 4:
Open the Aircraft Status in the Go App. You will see that the app will tell you that you need to upgrade the firmware. Open the upgrade area and click on the upgrade link.
Step 5:
The controller will disconnect from the device but will connect again if you just leave the controller on and the Go App open in the same screen in Step 4, the upgrade will start to update very very slowly.
Step 6:
The upgrade then runs for about 40 min and at the end the green light comes on.
It is very important that you follow these steps and not close the Go App or switch your controller off until you get to the end of step 6.
!! You must have patience and just wait !!
I hope that this will help. I had to do this with two controllers that had the same problem and it worked for both of them. It took me about a day to get the steps 100% after DJI said that the controller is faulty and I need to return it for repair. :@ How stupid do they think we are, what is the chance of two controllers going faulty on the same day in a span of one hour and this after I did an update that they said I needed to do......
Raymond
