Gimble Noise on new P4 - DJI Can you Comment?
1862 16 2016-3-18
gswilder
Flight distance : 18409 ft
Hello all, just got my new P4 from Apple a couple days ago.
Has anyone else noticed a noise from their gimble? I hear it each time I turn on the P4. Sounds like a squeek noise. It is not the "chirp chirp" noise when you turn the P4 on.
If I pick the P4 up and move it around a bit, I can hear the squeek when the gimble moves to try and maintain its stable position. If I move the P4, so the gimble is kind of at it's max postion, the squeek squeek repeats. So it is not a mechanical squeek, but some noise coming from the gimble or it's motor or sensor?
Never noticed this on my P3P. And the video seems pretty stable in flight, so not sure if an issue.
Anyone else notice this?
Thanks in advance.
G.
2016-3-18
Thacyoon
Norway
Think I know what you mean, same for me. By the way, have you also noticed a "new" engine sound? A high pitch sound from the propellers/engine when hovering in front of you?
2016-3-18
labroides
Flight distance : 9991457 ft
Thacyoon Posted at 2016-3-19 18:12
Think I know what you mean, same for me. By the way, have you also noticed a "new" engine sound? A h ...
Are you guys hearing the fan inside the body?
2016-3-18
Thacyoon
Norway
labroides@yahoo Posted at 2016-3-19 08:52
Don't think it is the fan. I have heard the fan without engins running, it is not a fan sound. The sound reminds me of a broken bearing, or bearing with too little grease...
2016-3-19
gswilder
I agree, it does sounds like a bearing with no grease. And I have heard the fan and other sounds the previous posters are describing.
Glad to know it's not just mine. I believe it is a sound generated by P4 computer. Like I said when you twist it to where the Gimble hits max travel, it does a repetitive squeek squeek squeek.
So far, the video on mine is fantastics, along with still photos. I do believe the video/stills are slightly better than the P3P I own. But being an amateur/pro photographer, it's all very subjective. Could just be that DJI tweeked the standard camera settings for saturation and contrast/etc.
Definitely handles better than my P3P. I have noticed a little more "drift". But it was a little windy yesterday, so not sure if that is the problem or not. I did do an IMU calibration after the initial firmware upgrade, but maybe need to do another one. I can understand horizontal drift, but mine seems to be moving vertical up an down a half foot or so.
Thanks all. Lets keep this thread going on the "the squeek".
2016-3-19
icsrz
Got the same. Its noticeable while carrying it. I turn it up to side or downward and will make a quick squick/grinding/farting sound. I hope it's not big deal in long term.
2016-3-19
gswilder
A poster on phatompilots said he had the noise and returned it. New one did not have the gimble noise/squeak.
2016-3-19
lee.lambie
Same noise here to, any help Dji ???
2016-3-19
lee.lambie
2016-3-20
gswilder
DJI I know you monitor this forum. Can you provide any feedback on this issue?
I'd like to have some advice, before I send it back for a replacement.
Thanks
G
2016-3-20
gswilder
FYI... ordered a replacement from Apple. Does NOT have the squeak sound. Haven't flown it yet, so we will see.
2016-3-24
larry.marshall
Flight distance : 72 ft
I have the same squeak issue with the gimbal.  I guess I'll call tech support tomorrow.
2016-3-24
Robertjfranklin
Thacyoon Posted at 2016-3-19 06:41
Don't think it is the fan. I have heard the fan without engins running, it is not a fan sound. The ...
Hey man have a question for you regarding this! Any chance you can accept my request?
2016-5-10
alish1992
Iran
Hi friend
I think i have some problems
when i twist my P4 left about 45-50 degrees, gimbal starts vibrating and squeezing
Do you have this broblem or somthing like this(twisting front, left, ...) too?
Please E\explain that with detail
Thanks so much
2016-5-28
alish1992
Iran
alish1992 Posted at 2016-5-29 01:53
Hi friend
when i twist my P4 left about 45-50 degrees, gimbal starts vi ...
Please help me dear friends
2016-5-29
usarfireman
Flight distance : 79957 ft
Ordered mine from Apple went to collect it and tested my one out in Apple Store as seen on YouTube about this problem and it had the gimbal noise so they changed it for another one, this one was fine just a pity another problem cropped up a few days later so that went back as well.
2016-5-29
ville.honkonen
Flight distance : 80919 ft
Finland
I have same problem, dji has email me that is not a problem.
2016-5-29
