Ronin M Follow Focus Mount and Lens Support
1224 5 2016-3-19
medavidson
When I added the mount and rods (http://store.dji.com/product/15mm-rod-set), the lens support is no longer mountable.
The problem is that the screw that came with the lens support is not long enough when the mount and rods are attached.  This seems like a simple one.
Any ideas?
Mark
2016-3-19
medavidson
Could it be that I need this:
http://www.bhphotovideo.com/c/pr ... rt_thumb_screw.html
Mark
2016-3-19
valealvarez.s96
Argentina
medavidson Posted at 2016-3-19 21:40
http://www.bhphotovideo.com/c/product/1070614-REG/dji_cp_zm_000098_le ...
I made my own FF rod for my Dji focus on a lathe, $70 is quite expensive for that thing.
2016-3-20
medavidson
valealvarez.s96 Posted at 2016-3-21 01:58
Im past the expensive part, now I need to get to the solution part.  This seems not only a simple fix, but one the engineers at DJI must have considered.
I can't find anything on it anywhere.
2016-3-21
valealvarez.s96
Argentina
medavidson Posted at 2016-3-22 07:06
Im past the expensive part, now I need to get to the solution part.  This seems not only a simple  ...
Just drill it a few milimiters and then you are good with the screw, you can use sand paper too, it's aluminium, easy to work with
2016-3-22
DJI-Adela
This issue will be reported to our relevant Dept. for review. Thanks for your feedback!
2016-3-24
