Start in Free Fall
2695 19 2016-3-20
Nink
As we all know if you put the contollers at 5 oclock and 7 oclock the engines shut off.  It is probably not a good idea to do this if you are more than 1 inch above the ground.  Question if you turn off the engine at say 100m above the ground and go into a free fall can you restart the engines during the free fall and regain contriol?   Has anyone tried it?
2016-3-20
Nink
Flyin'Bryan Posted at 2016-3-20 15:43
Once and only once have I done such a thing, not sure if it would work every time, but in theory, ye ...
I know it rights itself if you put it upside down.  Turn it on fly to 6 feet, hover and then grab the bottom and flip the quad upside down it will flip back over and hover again.
2016-3-20
rreindl
Flight distance : 6491926 ft
I have only done this in the simulator and it worked as I had the same question.
2016-3-20
Nink
Flyin'Bryan Posted at 2016-3-20 15:50
Read above, I elaborated my story a little more so it makes more sense.  But yes, you can CSC and  ...
thanks I am not sure i have the guts to do this yet.  I was looking for a good shot into a canyon today fast spin shut motors, drop, restart but could not bring myself to try it.
2016-3-20
mrGREEK360
Flight distance : 236414 ft
Nink Posted at 2016-3-20 16:09
thanks I am not sure i have the guts to do this yet.  I was looking for a good shot into a canyon  ...
Don't lol, warranty will be void if it does crash due to this stunt.
2016-3-20
mcphipps900
Flyin'Bryan Posted at 2016-3-21 04:12
Into a canyon?  May not be the best idea, if you fall, and lost signal,... Woooo.. You'd regret th ...
Bryan, is there anything out there you haven't done with a drone yet?
2016-3-20
Nink
mrGREEK360 Posted at 2016-3-20 20:12
The perfect shot or protect your warranty.  Do you still have the box your drone came in?  Well pack it back up, because you purchased your drone for all the wrong reasons.
2016-3-20
Nink
Flyin'Bryan Posted at 2016-3-20 22:36
Let's see... If bounced a p1 off a rock cliff at about 70 feet into a large pool of water.
I've cra ...
Nice:  and I bet not once did you say "would this void my warranty"  :-)
2016-3-20
Kneepuck
Flight distance : 275105 ft
I wonder,  though,  if the Phantom were upside down when you tried csc,  would it work?  Because I have seen several post where the Phantom flipped over and the op did a csc to stop the motors and it did not work.  I don't think I'll be testing this myself,  just wondering if you did a csc at 500 meters,  waited a bit for the drone to fall and then did csc to restart,  would it if it were upside down at the time?
2016-3-20
Northofthe49th
Nink Posted at 2016-3-21 04:09
Kind of like jumping out of a perfectly good airplane!!
And for those so inclined to want to know how long it would take your bird to drop 200'...it would be approx 3.5 seconds....give or take a fraction of a second...so doing a CSC in that time to stop and another to start the engines in that time is going to be....kind of....tricky....
Check out the splat calculator (splatulator!).....https://www.angio.net/personal/climb/speed
2016-3-20
Geebax
Kneepuck Posted at 2016-3-21 14:19
I wonder,  though,  if the Phantom were upside down when you tried csc,  would it work?  Because I h ...
In those situations you mention, when the aircraft has flipped upside down and does not appear to be responding to the CSC, I reckon it is because the aircraft is trying to right itself. There is a video somewhere in which a guy deliberately flips a Phantom upside down with his hands while it is flying, and it immediately rights itself.
Edit: I found the clip, take a look at this:
2016-3-21
Northofthe49th
Geebax Posted at 2016-3-21 16:02
In those situations you mention, when the aircraft has flipped upside down and does not appear to  ...
Yep,
Here you go...
2016-3-21
duritsch22
Northofthe49th Posted at 2016-3-21 14:13
And for those so inclined to want to know  ...
2016-3-21
Bhujang
Flight distance : 534587 ft
Also worth noting in the new fw 1.7 csc is now left stick bottom right corner and press RTH. Works much faster than both sticks down to inside corners as well. Mine shut off really fast compared to the old command.
2016-3-21
pfalcon
What I don't understand...  Why don't these drones that appear to be so adept at righting themselves when turned upside-down, etc. recover when a bird strikes?
2016-3-21
Craig Rogers
Flight distance : 168445 ft
Flyin'Bryan Posted at 2016-3-20 20:12
That sort of brings me to another question I often think about by have never asked.
If you start on the top of a canyon and descend into the canyon, does RTH still function as normal?  I guess if you set the RTH alltitude at 30m and descent 200 meters it will climb 230m to start RTH?
Sorry for the hijack.
2016-3-21
Kneepuck
A bird strike is usually different because there is usually prop damage.  That makes it much more difficult for the Phantom.
Yes,  if you fly below home point and initiate  rth,  the Phantom will still climb to rth altitude and go home,  so long as home point is more than 20 horizontal meters away.
2016-3-21
R&L Aerial
Flight distance : 298100 ft
Flyin'Bryan Posted at 2016-3-20 15:42
I have actually, with my p3pro... And It pulled out, I was at about 200 feet when I did it.   The si ...
I had something similar happen, my phantom 2 was inches from the ground when it righted itself, at one point it was upside down at full throttle. I too thought it was all over.
2016-3-21
wellsi
Flight distance : 8330187 ft
Craig Rogers Posted at 2016-3-21 15:41
If you start  ...
That is a perfect off-topic hijack but, if you set your home point at the take off point  top of the canyon, the bird will fly up to the RTH altitude you set, which will be eg 30 metres above your original take off point.  Being in the canyon below take off height is irrelevant.
I often fly down a hill and see my altitude show as a negative number.
2016-3-21
Michael M
Flight distance : 1984898 ft
Flyin'Bryan Posted at 2016-3-21 10:36
I've cra ...
Dam!!
2016-3-21
