Rnfaust
Flight distance : 734938 ft
I don't know if anyone noticed, but in the GO app on IOS, the Home Point icon disappeared from the left side of the main screen. Now there is just the Take off/Landing icon and the RTH icon.
So what you say? Well if you are like me, and few are I'm sure, you might need to reset your Home Point after take off. I do because I often take off from under a covered deck. Sounds crazy, but I have a good reason. I don't want RTH to land my P3 on the roof.
The missing Home Point icon is the Go app button that resets your Home Point.
I just investigated and they have moved it to the settings menu (upper right). Then select the MC settings menu (top tab) and there it now resides. I'm ok with that. Only 2 menus in.
I guess they moved to avoid confusion between it and the RTH button above it. I can easily imagine some poor panicked guy trying to RTH in an emergency and accidentally resetting his home point to the P3's current location because the buttons looked similar and were located together. No problem now.
Related - that's probably why they are rethinking the CSC procedure to stop the motors. |
