Harb
So you are saying the V2 is 1 Watt output...... not sure about current FCC licensing but here that would require an apparatus licence to be able to use it ?
The Pro Specs clearly state 20dbm EIRP so I was wondering if you can point us to the 30dbm specs, as I have 2.4Ghz links that output 30dbm that are good for at least 30kms line of sight if not more depending on the antennas used.
Not shooting at you here, I'd just like to see where this info is available.
For the record, My Inspire was one of the first half dozen into the country, and its good for at least 2 miles LOS , maybe further, I haven't really tested it further.
This cannot be the problem anyway.......he is not getting pictures with the RX and The TX 12 " apart....this is an out and out fault.
Incedently, I am still waiting for the X5R to upgrade from my Current version, but in the meantime if anyone near sydney wants to know, I can certainly measure the output and put this to rest......it will require some disasembly lol.
