Phantom 2 with Zenmuse H3-3d and GoPro Hero 3 + FPV Solutions
1946 0 2016-3-23
lewis.bv
I have a problem I don't know how to solve. I have tried an FPV solution before, but it went terribly wrong. The setup I used was the following set up. http://www.amazon.com/Plug-Play- ... _detailpage_o00_s00
http://www.amazon.com/coaxial-co ... _detailpage_o01_s00
http://www.amazon.com/FlySight-B ... _detailpage_o02_s00
http://www.amazon.com/Fatshark-I ... _detailpage_o04_s00
http://www.amazon.com/Immersion- ... _detailpage_o05_s00
(the adapters were ordered because I ordered two of the same antannaes, and the adapters were needed to fit one to the monitor.)
The link to the video where I got the parts from is here:
Now, what went wrong was somewhat human error. At first, I got all of the parts alligned perfectly and what not, and the set up should have been fully functional. But for some reason, no video feed was showing up on the monitor. (yes I had the gopro on NTSC, the cable from the zenmuse plugged into the gopro, the monitor on NTSC, and the monitor on the correct channel.) But, there was a flicker, meaning there should have been video feed. So, I figured that it was the plug and play cable that was screwing things up, because the transmitter was connecting to the monitor, and the gopro was on. So I took the hard route by doing some soddering. I got lazy, and didn't cover the live wires, and on start up, the live open wires touched, and fried the cam port. A spark and a puff of smoke came from the port. The cam port is the port where the fpv cable comes from. But this port is now toast, and won't work. After sending all the parts back, and getting most of my money back, I don't have an FPV solution. Can anyone help me with this, and provide a set up that doesn't include that cam port? Thank you in advance. (watch the attached video to understand what  the cam port is.)
2016-3-23
