jimhare
Flight distance : 239035 ft
Yeah, few things going on here. First of all the compression itself causes a slight flicker in luminance levels because of the GOP structure.
Then you have artifacts in the shadows which creates a dancing effect, which can also happen with tight lines or detail.
So my opinion is everything you are seeing is happening because of the compression.
I'm looking forward to seeing some high detail footage from the X5R, which shouldn't suffer from any compression issues.
