Flash light Mode -
1501 12 2016-3-24
Davidaw
Russia
Silly Question!
I'm struggling to find the benefit or use of this mode, what am I missing?
2016-3-24
rodAndTheCat
New Zealand
It gives you a very low angle of view. You can also turn the osmo upside down and get an even lower view- great if you are following young children .
Rod and the cat
2016-3-24
DaveK
It's good for filming small dogs!
2016-3-24
Davidaw
DaveK Posted at 2016-3-25 01:46
http://www.youtube.com/watch?v=rb7ye_dEPnA
Nice DaveK!
2016-4-2
Davidaw
rodAndTheCat Posted at 2016-3-24 12:51
It gives you a very low angle of view. You can also turn the osmo upside down and get an even lower  ...
Gosh!  I'd forgotten I'd posted that question, been away for a while.
Yes the upside down thing I've cracked!  and finding quite useful but I've found you can't easily transition from upright to horizontal! (or is that something else I'm missing!)
2016-4-2
joshuanicholas1
Indonesia
Flashlight mode has also been proven to be more smooth when filming then when you are holding it upright. I saw it in a YouTube video
2016-4-2
Davidaw
Russia
joshuanicholas1 Posted at 2016-4-2 21:00
Flashlight mode has also been proven to be more smooth when filming then when you are holding it upr ...
Good to know thanks, I'll try that out!
2016-4-2
MyNameIsFrazer
Flight distance : 116247 ft
Yea 100% smoother than using it upright (Y)
2016-4-2
robind_r
MyNameIsFrazer Posted at 2016-4-3 05:50
Interesting - but why should that be?
2016-4-3
C.Birch
Flight distance : 56365 ft
robind_r Posted at 2016-4-3 09:11
Holding the Osmo in a flash light way, lets the front on the camera move up and down in a kind of a shock absorber way next to how your hands moving. Holding it up right and the camera will move up and down the very same as your hand does.
So upright gives the camera a 1 to 1 movement with how the hand moving, where the flash light way does not move in a 1 to 1 manner with your hand, because it's a more loose way to hold it so like i say it acts like a shock absorber.
2016-4-3
robind_r
C.Birch Posted at 2016-4-3 10:57
Holding the Osmo in a flash light way, lets the front on the camera move up and down in a kind of  ...
But I would have thought that you're only moving the camera position through ninety degrees, and that the gimbals would still be reacting in the same way.
2016-4-3
C.Birch
robind_r Posted at 2016-4-3 15:43
But I would have thought that you're only moving the camera position through ninety degrees, and t ...
Your moving the camera from a position above your hand whats going take in every up and down movement of the hand, to a position out in front of the hand and with a holding style thats a more lose hold, so the camera will not move the same amount as the hand does.
It's all about letting the camera float more in your hand and not take in all the movements.
2016-4-3
MyNameIsFrazer
If any of you guys follow Philip bloom on facebook he has been testing out a new accessory from dji that apparently totally removes all up and down movement. But honestly from his test shots i couldnt see a huge improvement from just using the Osmo in flashlight mode.
2016-4-3
