matt_goddard
Flight distance : 461004 ft
i am having the same issues with the update for the P4. I am using a PC and Android phone/tablet. My P4 is on firmware 01.02.0503 and the RC is on 1.6.0. The DJI app does not report any new firmware saying that the firmware is up-to-date. However, when I connect to the PC and use the DJI Assistant 2 says there is an update. However, every time I try and update it downloads ok, but loses connection at around 45% and again at about 53% and then files at 61% (I cannot recall the exact percentages). I have now tried this for five times with same problem each time. I can try on a different PC but I suspect have the same problem.
I am getting, since this update the P4 is currently on, occasional reports of weak transmission signals and I get interference and green and purple lockouts on the screen when I press the camera button during flight. The screen after the picture has been taken normally goes back to normal but this was not doing it before the unit updated to this current firmware. Having said that, I've only had the unit a few days so my experience with this P4 is very limited.
Is this update essential for me to install? Also does it seem to sort out the problems with the interference and the weak signal?
Many thanks everybody. |
