DJI-Ken
Flight distance : 1515312 ft
Your battery needs to be conditioned. I always condition my batteries when new by only using 50% capacity for the first 10 charges. You will get longer flight times as the battery is broken in.
I did a test today with a new battery (not recommended) and got 25 minutes. Forward flight in ATTI mode will give you the most efficient flight. It takes more energy to hover (transitional lift).
So, after 15 cycles or so you should get the rated flight time (also temperature/altitude dependent.
And the range is the same as the P3, if you lower the image transmission setting to 4Mbps in custom,you will get the same range as the P3. |
