PeterQR
Geebax Posted at 2016-3-25 15:02
That's an interesting one, as there is no write protection switch on a Micro SD card. My adapter has a write protection switch though, you might check it is not switched over on your adapter.
I was totally baffled by the same problem, then you said write protection could be on the sd card adapter, I checked, switched it off, success, thank you!!!!! |
