OSMO black screen after last DJIGO app update
12Next >
5407 44 2016-3-26
Paulo Paulino
Flight distance : 2774265 ft
Portugal
Looks this problem is very usual after last update on a lot of so called "old" devices.
I have exactly the same problem on my galaxy note II.
Before the update of DJIGO app all works perfect with my OSMO and my galaxy note II, now after update I have all the screen information and settings but no image , (black screen).
My OSMO is fine, on my p3p samsung galaxy tab2 after DJIGO app update, all works with no problem with my OSMO, but its a little big to hold on my OSMO .
Please DJI fix this for us or just provide a link to download old DjiGO app because that will fix the problem.
We don´t need new phones just to look for a small screen when we film with OSMO and change settings.
All was great before this update for OSMO.
Thanks.
2016-3-26
npie12
Flight distance : 62657 ft
I have a Galaxy S6, my daughter a iPhone 6 or 6s (can't recall) and this is also happening to my recently delivered OSMO.  I updated to the latest firmware and tried different devices including my iPad mini.  I can see the setting or OSD, the camera records voice and audio and responds to all commands but there is no video displayed.  I  tried reformatting the microSD card that came with the unit, removing and reseating it, removing and reinstalling the DJI Go app from the devices and still no luck.  I purchased the OSMO for my daughter but I can't have her go back to college with this because at this time it is not reliable.  DJI any help is appreciated.
2016-3-26
Paulo Paulino
Portugal
For me after update DJIGO app and before update OSMO firmware my phone image (galaxy note II) become complettly black (setting works but no image feed). I test imediatly my samsung galaxy tab2 sm-t815 and works fine. After that I try update OSMO firmware hopping for a fix, but no, firmware did not fix DJIGO app problem.
I read people are having the same problem on p3 after DJIGO update.
For me the problem is in DJIGO app not in OSMO/P3P firmware.
2016-3-26
yves.flymovies
Greetings from Germany - same here: Updated from v1.4.1.80 to v1.6.2.10 via app and the text file shows:  v.99.99.99.99 .... Success. But I do not see any live view. I will return it to my dealer - I am professional and this is not acceptable.
2016-3-26
npie12
yves.flymovies Posted at 2016-3-26 16:51
Greetings from Germany - same here: Updated from v1.4.1.80 to v1.6.2.10 via app and the text file sh ...
I was at the end of my patients and decided to try the following steps outlined below.
I changed out the microSD card to a Panasonic 16GB Class 10 from the Lexar that came with the unit.
I formatted the Panasonic card and copied the latest 1.6.02 firmware to the root directory of  the microSD
I performed the firmware upgrade again, this time from the microSD card and not from the DJI app.
I removed and reinstalled the DJI GO app on my Galaxy S6 (My daughter did not have to reinstall it on her iPhone)
We have been using the OSMO for 3 hours now turning it on and off, switching batteries and using various devices and the video feed has worked every time.  It works now on my iPad 2, iPad mini, Galaxy S6 and my daughter's iPhone.  I hope anyone else having this loss of video issue might benefit from these procedures that saved me a great deal of frustration.
*Update*  I could not believe the Lexar microSD card could have been the issue.  I decided to reformat that card which came with the unit and copy the firmware into the root directory and replace the Panasonic I inserted into the until.  It works.  I can only say reinstalling the firmware using the microSD and reinstalling the DJI App worked for me.  Also before I used the microSD to upgrade the firmware the DJI App would always give a notification that the firmware required upgrade.  Now I see the correct firmware version in the DJI App.
2016-3-26
DJI-Adela
Paulo Paulino Posted at 2016-3-26 20:50
For me after update DJIGO app and before update OSMO firmware my phone image (galaxy note II) become ...
Have you tried to re-install the DJI GO App? Make sure that the App version is the latest one, For Android, the latest DJI GO App version is 2.7.1
Galaxy note II is not  in our recommended mobile device list, if it's not completely compatible with DJI GO App, please change your phone.
2016-3-27
DJI-Adela
npie12@verizon. Posted at 2016-3-27 09:05
I changed o ...
Thanks for your feedback!
Just a kind reminder: sometimes, the SD card performance does have influence in the live feed. It's wise to always check the SD card.
2016-3-27
DJI-Adela
yves.flymovies Posted at 2016-3-27 04:51
Sorry about the problem.
If you need any help, please contact us anytime.
I hope your dealer will help you to figure out the issue soon.
2016-3-27
hdraye
Saudi Arabia
npie12@verizon. Posted at 2016-3-27 04:05
I changed o ...
Hi
How can you reinstall a successful update please?
Mine says update successful, but no video stream, and I want to try with another SD card as per your message, but it says that I can not update as the firmware is same or older.
What is the trick to do so please?
regards
Hani
2016-3-30
DJI-Adela
hdraye Posted at 2016-3-31 03:43
Hi
Mine says update successful, but no video str ...
Hi,
If you've upgraded the firmware to the latest one successfully, you don't have to do it again, otherwise, you may always get a result: abort. Does the DJI GO App show the correct firmware version as v1.6.2.10?
Have you upgraded the DJI GO App's version to the latest version v2.7.1? Can you see the OSD information?
What's the model of your mobile device? Please try to re-install the DJI GO App and see if you can solve your problem.
2016-3-30
hdraye
Saudi Arabia
DJI-Adela Posted at 2016-3-31 05:25
Hi,
If you've upgraded the firmware to the latest one successfully, you don't have to do it again, ...
Yes, Yes and yes
I tried on OPI phone, Mate 7 and Iphone 6 plus, all no streaming
When I check my sd card after taking a video, importing fail saying no files on card, but using file explorer I can see the videos and play them.
2016-3-30
DJI-Adela
hdraye Posted at 2016-3-31 11:42
Yes, Yes and yes
When I check my  ...
Thanks for your answer!
So, the problem may be out of your SD card. After recording, copy the files from the SD card to your PC  (You can use a SD card reader to plug in the card to your PC or Micro-USB cable to connect to the Osmo and your PC) and check the recordings.
May I know the model of your SD card? Make sure that your card is compatible with the Osmo.
Before your further test, please format the SD card in DJI GO App (Gear setting->Camera->Genera->Format SD Card). Without pluggin the SD card, can you see the live image in the App?
2016-3-30
hdraye
Saudi Arabia
DJI-Adela Posted at 2016-3-31 07:09
So, the problem may be out of your SD card. After recording, copy the files ...
Hi
It's a Lexar 633x (16gb) that came with osmo.
This is my file after several tries:
========== 2014.01.01 00:00:10 remo-con disconnect======
Packet: OSMO_FW_V01.00.01.19.bin
Upgrading ...
Result: Success.
========== 2016.03.30 08:58:08 =====================
Packet: OSMO_FW_V01.06.02.10.bin
Upgrading ...
========== 2014.01.01 00:00:20 remo-con disconnect======
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:08 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the device.
========== 2014.01.01 00:00:09 remo-con disconnect======
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.03.30 21:37:17 =====================
Result: Abort.
Result: Abort.
========== 2016.03.30 21:44:24 =====================
Result: Abort.
========== 2016.03.30 21:44:50 =====================
Result: Abort.
Result: Abort.
========== 2016.03.30 21:48:43 =====================
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:06 remo-con disconnect======
Result: Abort.
========== 2014.01.01 00:00:07 remo-con disconnect======
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.03.31 07:23:25 =====================
Result: Abort.
========== 2016.03.31 07:25:08 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.03.31 11:14:46 =====================
Result: Abort.
2016-3-31
npie12
hdraye Posted at 2016-3-30 15:43
Hi
Hello, sorry for the delay in replying but I no longer have the OSMO with me.  I bought it as a gift for my daughter in college.  Our problem seemed to be somehow related to the way we did the firmware upgrade using the DJI app.  The DJI app kept saying a new firmware was available and we would perform the upgrade again.  I finally decided to upgrade it the way I do my Phantom 3 Pro.  I extracted the firmware, copied the .bin file to the root directory on the microSD card, inserted it into the OSMO, powered it on and upgraded.  After that the video worked every time.  I ended up using the same Lexar that came with the OSMO.  Good luck!  My daughter likes it a lot!
2016-3-31
DJI-Adela
hdraye Posted at 2016-3-31 22:26
Hi
The result: success/abort shows that you've upgrade the firmware correctly.
If you have another compatible SD card, please try it with your iPhone 6 plus. (No more upgrade)
2016-3-31
Paulo Paulino
Portugal
Hi DJI-Adela.
My phone works perfectly with OSMO before this DJIGO app update.
I just install an old DjiGO app 2.6.1 and my phone works again as usual with my OSMO.
I hope developments can fix this in DJigo app, we don´t need big quality video feeds to use OSMO we only need some image to see where the camera is pointed.
Edited:
PS. I cannot activate video cache wile recording, but video feed and camera commands are all working.
I also miss the new camera fuctions on DJIGO app 2.7.1 but better this then nothing for now.
2016-4-1
hdraye
Saudi Arabia
Paulo Paulino Posted at 2016-4-2 01:34
Hi DJI-Adela.
I just install an old ...
Hi
How can install the older copy of DJIGoApp please?
2016-4-2
Paulo Paulino
Portugal
Hi hdraye,
Because Dji did´t provide a link I download version 2.6.1 of DJIGo App from https://apkpure.com/dji-go/dji.pilot
Hope it helps.
2016-4-2
lieske
Is there a way to downgrade the firmware of the osmo?
2016-4-3
DJI-Adela
lieske Posted at 2016-4-4 15:14
Yes. You can download the OSMO Firmware at http://www.dji.com/product/osmo/info#downloads, extract the bin file to your SD card and downgrade the firmware one version by one version. (The downgrading procedures is similar to the process of upgrading, please refer to the document in our official website: How to Update Firmware ).
2016-4-4
DJI-Adela
hdraye Posted at 2016-4-2 22:09
Hi
For a better using experience and substantial functions, the latest DJI GO App would be recommended.
2016-4-4
DJI-Adela
Paulo Paulino Posted at 2016-4-2 06:34
Hi DJI-Adela.
Hi, Paulo
Thanks for your reply!
The latest DJI GO App will provide us with more features and better performance by installing into a compatible mobile device.
If you prefer the older version, please be careful with any upgrade in the future, make sure you've read the Release note first and decide if it's necessary for you to upgrade it or not.
2016-4-4
lieske
DJI-Adela Posted at 2016-4-5 06:18
Yes. You can download the OSMO Firmware v1.4.1.80 at http://www.dji.com/product/osmo/info#download ...
Hello,
this does not work for mer.
The log file says:
: The firmware on the SD card is identical to or older than the current firmware on the device.
2016-4-5
DJI-Adela
lieske Posted at 2016-4-5 16:49
Hello,
The log file says:
Hello!
Could you please show me the "OSMO_FW_LOG_AB.txt" file located on the Micro SD card root directory? You may need to enable the "display hidden folders" option on your computer to find it. (Please just show me the log record of your last several attempts if it's very long)
2016-4-5
lieske
[00008696]========== remo-con disconnect. boot(15) ============
[00008764]Packet [C:\OSMO_FW_V01.04.01.80.bin] detected, card sn [0x816224e4].
[00008837]Packet upgrade start...
[00008916]Packet checking...
[00008992]Packet vlink 01.04.0180 <-> 01.02.0160.
[00009060]Record vlink 01.06.0210 <-> 01.05.0200 (flow = 6).
[00009137]Packet upgrade failed at packet checking.
[00008764]========== 2016.04.04 09:26:37. boot(1) ============
[00008831]Packet [C:\OSMO_FW_V01.04.01.80.bin] detected, card sn [0x816224e4].
[00008895]Packet upgrade start...
[00008976]Packet checking...
[00009051]Packet vlink 01.04.0180 <-> 01.02.0160.
[00009125]Record vlink 01.06.0210 <-> 01.05.0200 (flow = 6).
[00009192]Packet upgrade failed at packet checking.
[00008711]========== remo-con disconnect. boot(15) ============
[00008787]Packet [C:\OSMO_FW_V01.04.01.80.bin] detected, card sn [0x816224e4].
[00008859]Packet upgrade start...
[00008931]Packet checking...
[00009005]Packet vlink 01.04.0180 <-> 01.02.0160.
[00009075]Record vlink 01.06.0210 <-> 01.05.0200 (flow = 6).
[00009144]Packet upgrade failed at packet checking.
[00008890]========== remo-con disconnect. boot(15) ============
[00008956]Packet [C:\OSMO_FW_V01.06.02.10.bin] detected, card sn [0x816224e4].
[00009026]Packet upgrade start...
[00009102]Packet checking...
[00009170]Packet vlink 01.06.0210 <-> 01.05.0200.
[00009240]Record vlink 01.06.0210 <-> 01.05.0200 (flow = 0).
[00009311]Done.
[00009374]Version checking[1]...
[00009466][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009542][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009721][01 00][00] v2.65.5033 -> v2.65.5033
[00009791][01 01][00] v2.65.5033 -> v2.65.5033
[00009875][04 00][00] v1.29.0.92 -> v1.29.0.92
[00009956][09 00][00] v0.0.0.81 -> v0.0.0.81
[00012027]Packet upgrade cancelled at version checking.
[00008803]========== remo-con disconnect. boot(15) ============
[00008871]Packet [C:\OSMO_FW_V01.06.02.10.bin] detected, card sn [0x816224e4].
[00008941]Packet upgrade start...
[00009018]Packet checking...
[00009086]Packet vlink 01.06.0210 <-> 01.05.0200.
[00009154]Record vlink 01.06.0210 <-> 01.05.0200 (flow = 0).
[00009222]Done.
[00009286]Version checking[1]...
[00009382][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009483][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009555][01 00][00] v2.65.5033 -> v2.65.5033
[00009622][01 01][00] v2.65.5033 -> v2.65.5033
[00009706][04 00][00] v1.29.0.92 -> v1.29.0.92
[00009782][09 00][00] v0.0.0.81 -> v0.0.0.81
[00011854]Packet upgrade cancelled at version checking.
[00008893]========== remo-con disconnect. boot(15) ============
[00008961]Packet [C:\OSMO_FW_V01.04.01.80.bin] detected, card sn [0x816224e4].
[00009034]Packet upgrade start...
[00009109]Packet checking...
[00009184]Packet vlink 01.04.0180 <-> 01.02.0160.
[00009252]Record vlink 01.06.0210 <-> 01.05.0200 (flow = 6).
[00009323]Packet upgrade failed at packet checking.
2016-4-5
dcooper2025
I also have the problem where with latest X3 update and OSMO update, I have NO video in the GO app.  PLEASE FIX.
OSMO update via app went successfully and X3 update on Inspire went successfully.
Latest GO app. No video feed.
My OSMO is useless at the moment.
2016-4-6
DJI-Adela
lieske Posted at 2016-4-6 15:40
[00008764]Packet [C:\OSMO_FW_V01 ...
Thanks for your information!
After double check with our engineers, I have to apologize I delivered you a wrong message.
I'd like to clarify:
We can only downgrade one version one time. So, v1.6.2.10 can only be downgrade to v1.5.1.20, but the v1.5.1.20 is not available in our official website presently, so I'm afraid you can't downgrade to v1.4.1.80 directly from v1.6.2.10. In other words, it's not allowed to downgrade recently.
Sorry for any inconvenience caused and beg your pardon!
2016-4-6
DJI-Adela
dcooper2025 Posted at 2016-4-7 01:32
I also have the problem where with latest X3 update and OSMO update, I have NO video in the GO app.  ...
Hello!
Can you see the OSD in the DJI GO App?
For the problem of "No video feed", please try below troubleshooting:
1) Re-install the DJI GO App.
2) Check your SD card, format it in the DJI GO App.
3) Try Trigger + Record + Power Switch
If you need any further help, please let me know.
2016-4-6
dcooper2025
DJI-Adela Posted at 2016-4-7 11:28
Hello!
For the problem of "No video feed", please try below ...
Ok, tried all three things and still no video feed.  Any other ideas?
2016-4-7
ardyyudha
Flight distance : 156089 ft
Indonesia
me to i cant use osmo now,
please give us firmware V.1.5
2016-4-7
DJI-Adela
ardyyudha Posted at 2016-4-8 00:03
I'm sorry that the firmware can not be downgraded to v1.5.1.20, as you may know, the v1.6.2.10 has fixed some problems based on v1.5.1.20, so v1.6.2.10 is more stable.
BTW, may I know why would you like the firmware v1.5.1.20?
2016-4-7
DJI-Adela
dcooper2025 Posted at 2016-4-7 21:00
Thanks for your reply here.
I would like to discuss more about the same issue on your another new thread http://forum.dji.com/thread-48153-1-1.html
2016-4-7
ssstudiomx
Mexico
For me this start to happen before I update firmware,  I updated to try to fix it,  updates was successful but didnt solve the issue,  still there,  I allready update the app and still there I agree in one thing we do not have the need of buy or purchase new phones is not fair please Dji Help
2016-4-8
coffeebugg
Flight distance : 125 ft
Philippines
Dear DJI,
Telling us to buy new phones because your DJI Go App is not backwards compatible should not be our problem. What you should be making are backwards compatible apps.
I am unable to fully utilize my Osmo simply because of the lack of a live feed on my Lenovo A536.
I have (reluctantly) upgraded my Osmo's firmware after trying to downgrade from 1.6 to 1,5 then to 1.4 to no avail.
As of this writing I am using 1.6 firmware and trying out Go App 2.6 to hopefully get a live feed. While I may not be able to use newer features, I would gladly trade them for having a live feed while I'm shooting.
Get your act together.
2016-4-9
DJI-Adela
ssstudiomx Posted at 2016-4-8 21:36
For me this start to happen before I update firmware,  I updated to try to fix it,  updates was succ ...
Hello!
Your problem may not be caused by the firmware but the DJI GO App or your mobile device's properties.
When did the problem happen before? Had it worked ever before the issue?
The live image transmission is related to many factors, we need to analyze the cause based on your more details. Initially, please try these troubleshooting:
1) Check the SD card.
2) Check the DJI GO App, make sure the App version is compatible with the firmware version.
3) Check your phone, make sure the processor of your phone is capable enough to handle the DJI GO App and the images.
4) Make sure that the gimbal-camera is connected to the handle firmly.
5) Have you ever mount X3 white camera on the Osmo? If you have, that might make the Osmo can't recognize the X3 black camera, then please try Trigger + Record + Power Switch.
Any other further feedback will be appreciated!
2016-4-10
DJI-Adela
coffeebugg Posted at 2016-4-9 20:51
Dear DJI,
Telling us to buy new phones because your DJI Go App is not backwards compatible should n ...
Hello!
In order to support all the features in the DJI GO App, it does have some requirements on the hardware of the mobile device. We would recommend a mobile device with at least 2GB RAM...
We'll try to cover all kinds of popular mobile devices in the market, but as you know, it's almost impossible for us to test all the devices in the world.
We'll be appreciated with any of your feedback if it's not in our recommended list.
Thanks for your understanding!
If you need any further help with your problem, please feel free to let me know.
2016-4-10
ardy19
Indonesia
DJI-Adela Posted at 2016-4-8 11:18
I'm sorry that the firmware can not be downgraded to v1.5.1.20, as you may know, the v1.6.2.10 has ...
because after update to firmware 1.6 my phone cant live view again.
2016-6-28
DJI-Adela
ardy19 Posted at 2016-6-29 12:08
Hello.
Could you please tell me more information about your phone?
Please make sure both the firmware and the DJI GO App are the latest version.
Thanks.
2016-6-28
videoridus
Kyrgyzstan
Hello! I have the same problem, after installing the firmware OSMO Firmware v1.6.2.10 I have a black screen on your phone, other functions are working properly. What to do? You can return to the old firmware?
2016-7-2
HighRange Photo
Any word on a fix for this issue?
2016-12-3
12Next >
