werner.daehn
Flight distance : 350837 ft
Austria
Examples:
1. While the rig rides on a motorized dolly, it should look at the same point all times. Providing a nice overview shot where you can see the object first from front, then from the side and finally from the rear.
2. While on a CableCam, record the signals sent to the Ronin and repeat that. This way you can film the same sequence multiple times.
3. With the Ronin on the copter, keep looking at the same POI regardless of where the copter is at any time.
4. Ronin being static and based on its current GPS position in relation to the target object's position calculate the angles and let the Ronin keep tracking the object.
5. Panorama shots, where you want the Ronin to Pan by e.g. 360° in a given amount of time, say within 1 minute.
6. Use the tablet to control a remote Ronin by rotating and angling the tablet. If you rotate 20° left, so does the Ronin. If you look 45° up with the tablet, so does the Ronin.
7. Ronin is on a camera crane controlled by a stick, same stick should control the Ronin as well to add up the movements of both.
Common to all these use cases is the need of a flight controller, a microcomputer, a smartphone or whatever external control. But these devices require to send the absolute angles. Since you can't, the Ronin is not suited for any of these professional grade use cases.
With a simple and easy addition to support that as well, suddenly you could. Mine is the CableCam use case btw. It works with a 200USD gimbal but not yours at the moment.
