Latest inspire 1 update problems
4677 14 2016-3-27
prostreet1
Anyone else having problems with the latest update? Downloaded firmware to inspire 1 which seemed to work, controller says update..press to upgrade,keeps coming up as failed? Any help here?
2016-3-27
RichJ53
Flight distance : 1837356 ft
Make sure you only have the remote and the iPad and GO App turned on. DO NOT have the inspire 1 connected during the process. The remote update will finish and you shut it down and restart the remote... you should be good to go.
Rich
2016-3-27
prostreet1
Hey rich,thank you,I also noticed after the inspire 1 update,the controller had no sound? I couldn't lower the inspire 1 to put it away?
2016-3-27
RichJ53
prostreet1@comc Posted at 2016-3-27 11:48
Hey rich,thank you,I also noticed after the inspire 1 update,the controller had no sound? I couldn't ...
Did you complete the update on the remote?  It should make a beeping sound while it is updating but once it is complete you need to power it off and restart it again.
Sometimes the surface the Inspire is sitting on will not let the VPS work correctly. put it on top of the case and it should lower to travel position okay.
Rich
2016-3-27
DJI-Tim
please make sure you did everything as it shown in the video..,.
2016-3-27
ezfly
Flight distance : 2885043 ft
Slovenia
i have update the RCs and now i have RC SIGNAL LOST on both RCs any solution?
Inspire1 Pro X5 -   and NO i dont have X3 because i sold it...
2016-3-28
bety
Flight distance : 1097644 ft
Vietnam
ezfly Posted at 2016-3-28 15:06
Inspire1 Pro X5 -    ...
I have the same problem with my Inspire1 Pro ( 1 RC). Now I cannot use any more my Inspire1 and impossible to put it in low position.
2016-3-28
ezfly
Slovenia
i have send email to dji and we hope we get the fix soon ... i will inform you right away..
2016-3-28
R&L Aerial
Flight distance : 298100 ft
bety Posted at 2016-3-28 04:21
I have the same problem with my Inspire1 Pro ( 1 RC). Now I cannot use any more my Inspire1 and im ...
Did you try to re-bind the inspire to the transmitter?
2016-3-28
Wolfman
Flight distance : 405659 ft
R&L Aerial  Posted at 2016-3-28 20:08
DJI updates.....
No greater rush on the planet when they work without any issues.!
Come on DJI, it surely cannot be this hit and miss can it???
DJI Update Lotto
DJI Update Lotto
2016-3-28
prostreet1
Rich ,when we tried to update the remote..went through the process - never had a beeping sound that it was updating or a blue lite? The inspire 1 seemed to update,but the controller won't ,keeps saying retry? Has no sound when Turing on or off? Any suggestions
2016-3-28
ezfly
Slovenia
bety Posted at 2016-3-28 10:21
try this
2016-3-28
RichJ53
prostreet1@comc Posted at 2016-3-28 03:33
Rich ,when we tried to update the remote..went through the process - never had a beeping sound that  ...
Follow the video that Tim posted above, try to start over again with the RC. If you are still having issues then try reverting back to the last firmware and follow EZFLY's video below...
I hope you get it working, and if nothing else works you will need to contact DJI support
Rich
2016-3-28
bety
Vietnam
ezfly Posted at 2016-3-29 01:25
try this
https://youtu.be/3OYajs-xmJ4
Thank you for your help  EZFLY. With the update FW v1.8.0.93 everything is good now. I make flight tests just now.
2016-3-28
rbabcock19
Flight distance : 233993 ft
I had tried a few things on previous updates.  one of them just ended up being a bad cable.  The most recent update downloaded dji go on my phone then plugged it in to the transmitter and it worked (my phone has a curved back and doesn't fit in the cradle so I don't use it to fly).  My tablet would not work when trying to update but using another device worked for me.
2016-4-1
