Max Altitude
7346 23 2016-3-27
mbean5
Hey guys,
Quick question regarding altitude. I read conflicting reports everywhere regarding how high the DJI P3 Standard can go, both legally and its actual ability.
I was out today and when I got to around 400 ft it said that was the max but I could change some settings? Is that correct? And if so, how much farther can it go? Some places I read 1,500 ft.
Also, what is legal max altitude? Most things I read are about 400 (hence why that's why I was locked from going higher).
Any insight into this would be helpful. Thanks.
2016-3-27
labroides
Flight distance : 9991457 ft
The Phantom has a user adjustable height limit.
If you turn it off the Phantom will go to 500 metres above launch point.
2016-3-27
GTDrone
Flight distance : 2197703 ft
Guatemala
because you are in USA the legal altitude is 120 meters if you go higher than that you can get in troubles
i think that there is a license to fly higher than 120 meters may be some one else can correct me
2016-3-27
AlaskanTides
Flight distance : 1032293 ft
Just because you can do somthing does not mean it's wise to do so..... The 500m limit is extremely helpful if you live in a mountainous area..(planes don't fly at this altitude in these areas)
If folks routinely start flying 1300' in normal aircraft airspace then you can bet that DJI will limit this feature for all of us.
3DR has already set a hard limit at 400' in the USA..... They are a flop partly due to this.
2016-3-27
GTDrone
Guatemala
Flyin'Bryan Posted at 2016-3-27 20:44
Thats not true. You can fly higher than 400 feet. It os a guideline, (recommendation) not a law.
is this for real ?  i heard a lot of people from USA that  are scare about uploading videos flying at let say 200 meters of altitude because they don't want troubles with the FAA
so you are saying that is not a law is just a recommendation and everyone can fly over 500 meters ?
2016-3-27
GTDrone
Guatemala
AlaskanTides Posted at 2016-3-27 20:56
Just because you can do somthing does not mean it's wise to do so..... The 500m limit is extremely h ...
I live in a mountainous  areas and 500 meters is not enough at all ,  all the volcanoes and mountains here are higher than 2.5 km   , i want at least 1.5 km  to fly near to a volcano and thats not dangerous because planes doest fly around volcanoes
2016-3-27
GTDrone
Guatemala
Flyin'Bryan Posted at 2016-3-27 21:41
If I couldn't fly over 400 feet, I wouldn't be able to fly 2 blocks away from my house in 3 directio ...
nice to know , same here a live in an area with a lot of trees and mountains i really need to fly that kind of high because some times i need avoid all that obstacles
but thanks for answering
2016-3-27
blu3g3.gmail
Hi all, Is there any forum where DJI explains why did they set that limit?. I think it is totally random and nonsense; I do a lot of Mountain video and need at least 1km height but it can't due to their stupid restriction.
2016-3-28
microcyb
Flight distance : 1095955 ft
*grabs popcorn.  Oh hell, the hot topic again.
2016-3-28
GM01
Belgium
The height restriction is based on 500m above your take off point (=home point =0m)
2016-3-28
blu3g3.gmail
GM01 Posted at 2016-3-28 15:52
Yes, in fact, under some circumstances it will be more secure to fly over 500m..
2016-3-28
mbean5
Thanks guys. Very helpful.
2016-3-28
nigelw
Flight distance : 518084 ft
I'm happy with 500m even flying over mountainous terrain as any further it would be out of visual line of sight for me. It needs to be visible to the unaided eye on the UK by law.
2016-3-28
nigelw
Killswitch Posted at 2016-3-28 19:27
Dji banned my new IP address. Im out of here. Tired of playing games. Dji's Tahoe Ed is chasing me ...
Cheers fella, I'm sure you'll reappear eventually
2016-3-28
evsjas
Flight distance : 1995479 ft
I live in the mountains, if I need to go higher than 120 meters I drive up the mountain more.
2016-4-4
raveneapoe
golf_sierra@lib Posted at 2016-3-28 08:23
Flyin'Bryan is right. This is the latest of what the FAA says about operating drones / hobby UAS:
In ...
"Individuals flying for hobby or recreation are strongly encouraged to follow safety guidelines"
Notice the phrases " strongly encouraged" and "safety guidelines"
The same type of advice applies to running while holding scissors, it doesn't really say it's illegal.
2016-4-4
flormo2002
Flight distance : 12242710 ft
I'm sure this has been covered before too but take an example of flying up the side of a mountain and you reach 500 meters which is the limit from take off point.........You still have good visual on the tablets screen and you find a good spot to land. You then shut down the motors and log off the Go app. You turn the app back on and wait for the settings to stabilize. Will the app show this new location to be at ground zero and you can go another 500 meters up?
2016-4-4
SlingShot
Flight distance : 107838 ft
flormo2002@yaho Posted at 2016-4-4 15:26
I'm sure this has been covered before too but take an example of flying up the side of a mountain an ...
Im curious of this as well. I believe it's the measured distance between the AC and the RC.  I'm doubting it will work but willing to try next flight.
2016-4-25
bfd300
Flight distance : 73661 ft
400 ft from take off point.........not sea level
2016-4-25
DJI-Ken
Flight distance : 1515312 ft
bfd300 Posted at 2016-4-26 10:01
Max altitude is 1,640ft from home point.
2016-4-25
bfd300
I meant what is set by default in the GO app
2016-4-25
