DJI-Ken
Flight distance : 1515312 ft
You should store the battery at 50% or so.
If you fully charge the battery, it will auto discharge to the storage level (1-10 days depending on what you set it at) and just leave it until needed again.
And the battery will not auto discharge if left in the aircraft and you shouldn't long term store in the aircraft anyways.
Also, it may go into hibernation mode depending on how long you store it. So months later if you power it up and the red light goes on and will not turn off, that just means it's in hibernation mode and let it sit for 5 minutes and the light will go out. Then fully charge and you are good to go. |
